SOURCE: deleting old words with friends games on the ipad
Push and hold app until jiggliing with x.Tap x to delete from ipad.
SOURCE: kindle fire will not load words with friends
Step one, download advanced task killer. It works great. When down loaded set the security level in the app to "low", the kill level to "aggressive", and the app kill rate to "whenever screen is off". reset your Kindle. (turn completely off, then back on) Try using your games again if that doesnt work then u might reinstall a game or two and see if that makes a difference. My fire did the same thing to me. Alot of time apps will run in the background and eat all of the RAM (memory) up and when you try to run games there isnt enough to do so. I had the same problem trying to play jetpack joy ride
1.Make sure device is completely powered off. 2.Press and Hold The Power and volume down button at the same time. 4.Select factory data reset in recovery menu. 6.Reboot System Now and you're finished!18 Mar 2013
How to Hard Reset Samsung Galaxy Tab 2 10.1 Android 4.0 Remove ...
https://www.youtube.com/watch?v=EeWiML00i9E
https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=reboot+Samsung+galaxy+2+tablet+10inch
SOURCE: How do I sync a Samsung galaxy tab 2 10.1 to a PC
You May Meer to activate USB Deb?t Mode https://www.google.nl/url?sa=t&source=web&rct=j&url=http://rescueroot.com/android/how-to-enable-usb-debugging-on-samsung-devices/&ved=0ahUKEwj2gb3a2LTYAhUECsAKHXluDNIQFggsMAI&usg=AOvVaw2i8yNE_vEXkefJt-Ug-QYr
Testimonial: "Thanks, It helped allot."
