I have a 2005 rendezvous that has tension pulley bolt broke off inside threads in head. How to remove the broken bolt without removing head? Is there a shorter belt to replace belt and bypass tension pulley?
SOURCE: !991 Olds 88...can I replace with a shorter serpentine belt?
Unplug wires going to the compressor, and let it freewheel, if it's not noisy in that mode. A/C compressor won't kick in if not connected. A lot less hassle than going the other way.
SOURCE: need to replace pulley for serpentine belt on a 2000 Eclipse
left need to use a air tool most likely
SOURCE: The diagram for the replacing the serpentine belt
Here you go.
Please let me know if this information is helpful. Positive feedback is appreciated. Thank You!
SOURCE: TENSIONER bolt has broken off of the TENSIONER pulley
your daewoo does not have an interference engine which means that if timing belt slips or breaks there wont be any valve or piston damage
SOURCE: replacing serpitine belt tension pulley
Lefty Loosey, Righty Tighty. As you look at the bolt from the front of the engine. It should loosen when turned counter clockwise. Curios though, why are you removing and replacing the tensioner? If your having trouble with belt tension it is most likely the belt.
Park the Pontiac in a safe work area and open the hood.
Inspect the top of the black plastic cover that surrounds the fan for the serpentine belt routing diagram. This diagram has the instructions for installing the new serpentine belt around the accessory pulleys.
Inspect the front of the engine and locate the automatic belt tensioner. The tensioner on the 1999 Pontiac model vehicles is located between the alternator and the crankshaft pulley. The tensioner has a pulley on one end with a bolt head in the center of the pulley. Use the bolt head to rotate the tensioner.
Turn the tensioner counterclockwise with the breaker bar and a metric socket. Pull the belt out from under the tensioner pulley with your other hand. Then, slowly let the tensioner retract until it stops.
Pull the belt out of the other remaining pulleys. Then, pull the belt out of the engine bay and lay it on the ground.
Route the new belt around the crankshaft pulley. Then, route the new belt around the other remaining pullleys by using the serpentine belt routing diagram for instructions.
Rotate the tensioner pulley counterclockwise with the breaker bar and socket. Then, slide the new belt under the tensioner pulley. Slowly let the tensioner retract until it stops. The tensioner pulls all of the slack out of the belt and brings the new belt to the proper tension. Remove the breaker bar and socket from the tensioner pulley.
Inspect the new belt to ensure that it is seated inside of all the accessory pulleys as directed by the diagram. Then, crank the engine and allow it to run for about 15 seconds. Turn the engine off. Inspect the belt again once more to ensure that
the belt is still around each pulley. Close the hood.
Locate the two belts on the left side (passenger side) of your Mitsubishi Lancer. The outer belt is a serpentine belt, operating four pulleys and the inner belt is your alternator belt.
Follow the serpentine (outer) belt to the three pulleys lined up vertically near the front of the engine compartment. Locate the middle pulley, which is the tension pulley for the belt.
Loosen the bolt on the middle pulley with a socket wrench by turning counter-clockwise. Do not remove the bolt, just turn it a couple of times. Loosen the tensioner bolt on the side of the of the pulley, facing the front of the vehicle.
Remove the serpentine belt and then loosen the bolt on the alternator. With the alternator loose, move it forward so that the alternator belt loosens up and then remove belt from the pulleys.
Install the new alternator belt by placing it over both inside pulleys. Tighten the tension on the alternator belt by moving the alternator back and keeping tension on it by holding it back with a long screwdriver. While the alternator belt is tight, use a socket wrench to tighten up the bolt on the alternator.
Place the serpentine belt back on the pulleys and then use a socket wrench on the bolt on the front of the tension pulley. Once the serpentine belt is tight, tighten up the bolt in the middle of the tension pulley.
Start the Mitsubishi Lancer's engine to test the alternator belt and make sure it is working properly. Once you have verified it is working, turn the engine off.
