Electrical Supplies Logo
T
Terry Flannery Posted on Sep 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I recently acquired a used Spa Pump motor. I would like to use the motor for something in my woodworking but need some info regarding how to wire it up.
The motor is labeled an Executive 48 in the spa pump motor world lingo. It is an A.O. Smith P/N-7-177803-02 motor, and I'm pretty sure it's a 1.5 HP even though the label shows --- for the HP line. It has a cord on that I'm pretty certain is 14/4 AWG, I cut the plug end off since it was equipment specific, and the motor is meant for single or 2-speed operation. The label also shows: #2 - Line, #3 - High Speed, #4 - Low Speed. What type of switch should I install on this so that I can run it at both high and low speeds? Also, is #2 the white wire/neutral, #3 for black and #4 for red and yes, it has a green ground. Should this be on a 20-amp circuit or larger? Thanks for your help!
Mr.Mike
Level 3:
  • Master 580 Answers
  • Posted on May 20, 2020
Mr.Mike
Master
Level 3:
Answers
580
Questions
0
Helped
195804
Points
1906
Hi there!
Take a look at pic 2 and pic 6 on this page.
The colors do not matter there is no forced set standard for wiring and colors but we are aware of commonly used color schemes.
Pole 2=Line
Pole 3= High
Pole 4=Low
Ground is Ground
https://www.spapumpsandmore.com/spa_pump_motor_2_speed_Century_BN50_115v_16_4a_p/mtraos-15115.htm
Good Luck!
Mr.Mike
5 Related Answers
Anonymous
  • Posted on Apr 19, 2009
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Anonymous
  • 3600 Answers
  • Posted on Jul 05, 2009
SOURCE: Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Anonymous
  • 20 Answers
  • Posted on Jul 12, 2009
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Anonymous
  • 368 Answers
  • Posted on Sep 06, 2011
SOURCE: I have old spa motor
The motor should work if you connect the black wire to L1, white wire to L2 and green wire to ground. The red wire should be cut so the conductor does not extend past the insulation and the end wrapped with electrical tape.This should be correct if the motor is a 120 VAC motor. If the motor is a 240 VAC motor then the white wire is not really neutral. It should be wrapped in both the motor wiring area with black electrical tape and the other end in the timer should also be wrapped with black tape.
If this causes a problem because you now have no low speed for the spa then the only way to get the low speed is to squire a 2 speed motor.
I hope this helps.
davidspra65638
David Spradling
  • 13520 Answers
  • Posted on Nov 18, 2017
SOURCE: I have a VITA Spa
red should be high black and white low low operates 120 volt then high uses black and red for 220 volt green to case
How do you correct under voltage to a pool pump?
need more info if connecting to 120 volts you must change the motor shunting see side of pump motor some you have to change the brown and white wires and some you turn a knob from 240 to 120
I installed a new pump motor. It has power, lights are working but jets are not. What wires could be wrong - I don't have clear red, black, white and green wires. The spa is a freeflow passport spa.
there should be a wiring diagram on the side of the motor make sure if you are running 120 volt you changed the shunting on motor or might have hooked up incorrect if no info call a professional
2answers
Pump not working
need more info does system have power to pump motor? if not check breaker if voltage from breaker check switch if you do have power to the pump motor sounds like bad pump motor
Emerson pool pump model k63cxesf-4793
Emerson is the manufacturer of the actual motor, not the entire pump. Many manufacturers use Emerson motors as a base for their pump systems,
You need to contact Emerson Motors USA for warranty info. Please have the "sticker" info on the pump motor available.
Changing hot tub pump flo master power cord to new waterway pump diagram say common white line to port no 1 port no 1 hase an orange wire on it allready wire leads in to motor housing. not sure where white...
DO NOT PLAY AROUND WITH THE WIRING OF THIS 2 PEED.
you can cook the motor in just a few seconds != junk
yes WHITE is common RED is low and BLACK is high
A picture of the connections in the back of the motor is needed for further assistance
Jay the pool pump repair guy in longwood Florida.
Whirlpool spa bath touchpad wiring
you need to acquire a wiring schematic from the manufacturer for your tub,....get all info you can think of i.e. model#, serial# name, etc. so when you reach a human on the phone, you can give them all of this required info they'll need to get you the right info you'll need to re-wire this thing,..good luck
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
