Question about Westinghouse SK-32H240S Television
Hookup for HD-Television and OLD VCR
I have a new Westinghouse SK-32H240S (HDTV), a 10 yr. old Philips SVA106AT22 (VCR), a 10 or 11 yr. old Thomson DRD222RD Direct-tv (sat. box), an Apex AD-1100W (DVD player), and a SSI Cineplex 220 (Pro-Logic surround sound system).
Also an Off-Air antenna for local channels.
Everything is hooked up and working fine except the VCR. I can play tapes but since the DTV transition I can no longer record. Is there some different way of hooking up the VCR or do I need to use a digital to analog converter box for recording and how would I hook things up to record one channel and watch a different channel from two different sources such as dish/antenna and visa versa, dish/dish, antenna/antenna. :-/
6ya staff
SOURCE:
Anonymous
  • 289 Answers
SOURCE: home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Posted on Feb 01, 2009
Anonymous
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
Anonymous
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
Anonymous
SOURCE: Need a service manual for SK-32H240S TV
They are now sending me a new TV
Posted on Jun 03, 2009
Anonymous
SOURCE: SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Posted on Jul 09, 2009
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
Lightning struck My SK-32H240s Widescreen HDTV and now it will not work. Is there a reset button or some way to fix this myself? No insurance and 2 years old
Hi:
If lighting struck the television then there may be a problem with the power supply, first thing to check for is the line fuse, if no standby light is lit on the front when you plug the set into AC outlet then the line fuse is blown and needs replacing.
Aug 22, 2010 | Westinghouse SK-32H240S Television
Westinghouse sk 32h240s problems less than 2 years old....sound but no video
Hello, it sounds like you need to change your LIPS board which has the power supply with the inverter board all in one board. You can find this part by emailing parts@wde.com, please make sure you include the model #, serial#, and TW#, all located on the back of the unit. If you would like more information you can also email me at westytech@wde.com. Please rate me if this information was helpful.
Jan 31, 2010 | Westinghouse SK-32H240S Television
Picture goes off sound stays on
Hi
Yes the problem has been solved. finally. The information on your web site was correct but the replacement board that I needed was no longer available. I ended up taking it to the local repair shop and he "worked on the board" that was messed up. Cost about the same as a new board would have, if I could have gotten one. Thanks for the great web site.
Dec 30, 2009 | Westinghouse SK-32H240S Television
I have a westinghouse sk-32h240s whin i retune it
No. Everytime you rescan channels it will dump any previously saved channels.
Jun 23, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Mar 28, 2009 | Westinghouse SK-32H240S Television
Westinghouse sk-32h240s hdtv
Lines, and the screen going black are common among this particular T.V., but some solutions to a similar problem were posted here.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Televison & Video Logo
115 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
