configuring this smc router depends on your internet service provider..
if your isp is cable , then connect the cables from the wall outlet to the modem and the modem to the router and the router to the pc..
find out the IP address is ipconfig (Start -> Run -> "cmd" [enter] -> "ipconfig" [enter]).
The command to ping the router is ping 192.168.2.1. Both are to be executed from a command prompt.
In the routers web interface, click on login (password would be either blank or smcadmin) -> Advanced setup -> click on WAN -> Dynamic IP address -> click on clone MAC address and save the settings.
and now u would be able to go online wired..
to go online w/ls
In the routers web-interface -> click on login -> Advanced setup -> wireless -> enable -> apply -> channel and SSID -> Set the following values:
SSID
: Set it to your name
SSID broadcast
: Enabled
wireless Mode
: Long range Mixed (11b + 11g )
Transmission rate
: 11/ 54/ 108 Mbps
Channel
: 6
g-nitro
: disabled
check in w/ls w/ls laptopt, u would c the w/ls n/w name which u have setup, connect to it u would go online w/ls
To setu ur router for a dsl connection..
In the routers web interface -> Click on login (password would be either blank or smcadmin) -> Advanced setup -> WAN -> PPPoE -> Enter the following values:
- Type in the Username and the password provided by your ISP.
- Set MTU = 1440.
- Set maximum idle time to zero.
- Save the settings.
And the w/ls settings r the same as mentioned earlier..
check it out
