Its ******* to swicth electricity for a tenant as far as i know .
SOURCE: Tenant says fridge is not cold enough and that food has gone off
I would check to see if the heater is working? It would behind the plastic back wall of the freezer. if its all frozen up and ice all over, get a hair dryer and melt ice and get a new heating element. cost is about 50 dollars
SOURCE: need to a buy a coin mechanism to put on a washer/dryer
i have the parts u need call me at 484 680 1952
SOURCE: my fridge is frozen at the back but seems too warm
Let this unit completely defrost and thaw(sevral hours) which might bring it back with little or no additional repairs.These units will lock up on excessive ice and will not circulate...good luck
SOURCE: Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
SOURCE: The cooling unit stops running
Could be defrost sticking or the compressor not starting...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
