SOURCE: Shuffle mix max
That's not actually how you delete songs from the player. When you connect it to your computer you will see a new removable disk called Mix Max in your My Computer icon or in Computer if you have Vista. Open up that Mix Max icon and then you can highlight and delete only the songs you don't want or all of them.
SOURCE: can not change ringtone says
try to go on the settings from your inbox or your messages and change it on memory card instead of using phone memory as your message or file storage. the phone is telling you that is FULL because your using phone memory for your inbox storage and not your memory card.
thank you for using fixya
CHARCOIS
SOURCE: How do I shuffle music on this device?
When you first go on to your music, there should be suffle right there above your first song. If i think that is what you are asking then there's the answer.
SOURCE: samsung f300 says memory full
if you have any games that you dont use or rarely use try delete them then try find out if you have any service messages if you do try delete them too, if that dosen't work then you will have 2 options; contact your phone operator, or take your phone to be checked by/ unlocked by your nearest market stall.
SOURCE: I plugged my GoGear CAM
Welcome to Fixya
It could be that all the files are hidden. Go to the folder options when you click My computer then go to vie tab then put a mark that saysa show hidden files. Go back to the player again and see if you you were able to see the files now.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
You can set your player to play songs randomly (Shuffle All ) or repeatedly (Repeat
One or Repeat All ).
1 From the main menu, select > Play mode.
2 Press 3 or 4 to scroll up or down the options.
3 Press 2 to select an option.
While you are playing music, you can see the above active play mode screen.
Consumer Care can be reached at 1-888-744-5477.
Hope this helps. If so, let me know by rating this solution. Thank you.
