Question about Yamaha Music
My Yamaha MM8 turns on, but produces no sound. I've reinitialized it and verified the LOCAL setting is ON. This is my primary instrument and I'm getting very worried. Thank you if you can help at all.
3 Suggested Answers
6ya staff
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: i have annew yamaha mm8, it's showing only half
Since it is brand new, IMMEDIATELY exercise your warranty rights as the LCD will probably have to be replaced.
Posted on Dec 26, 2010
Fred Yearian
  • 5603 Answers
SOURCE: I cant get any sound
See if you get sound from headphones.
Posted on May 01, 2011
I have a Yamaha MM8. Why doesn't it power up even if it is plugged?
I'd suspect the power supply is dead (check it with an ohm meter), or that the internal fuse is blown (open it up and check).
Jun 25, 2016 | Yamaha MM8 MUSIC SYNTHESIZER
Sustain issue with Yamaha MM8
Your pedal may be the wrong polarity for this keyboard. Different manufacturers wire differently. And some use trs 1/4" and others use ts 1/4". Contact Yamaha customer service to get the correct pedal for your instrument.
Apr 08, 2016 | Yamaha MM8 MUSIC SYNTHESIZER
Why does my yamaha mm8 doesn't have any sound? I try the headphones and there's no sound there either.
Assuming the volume is turned up, you can try initializing the keyboard (page 35 of the manual), but that will erase all stored backup data and reset to initial default settings. You might wantt to call Yamaha directly to discuss their suggestions. Here's their support link-
Digital Pianos Keyboards Guitars Drums Live Sound and Music Production...
Jul 28, 2015 | Yamaha Music
How to factory reset a Yamaha p155 piano
Turn off the p155 power.
Press & hold down the rightmost key (C7) while turning on the power. Once the power is On release the C7 key. It should reinitialize to the original factory setting
Nov 03, 2012 | Music
How can I fix a yamaha clavinova clp-152s that no longer produces a clean sound? The tones sound muffled to some degree.
It could have a capacitor failing in the amplifier section, or primary oscillator section. it might also be a failing output transistor on the amplifier. If the amplifier has gotten noiseir, suspect a faulty transistor.
Apr 26, 2012 | Music
I have annew yamaha mm8, it's showing only half screen, how can i repair it ?
Dec 26, 2010 | Yamaha MM8 MUSIC SYNTHESIZER
I'm trying to midi from my mm8 into my mm6,but will not receive the midi signal,i went into utility ,and all the settings seem to be set right,what am i doing wrong?
I assume you have MIDI out MM8 cabled to MIDI in MM6?
You also have to setup the MIDI to be emitted by the MM8 and define the MIDI channel(s) to be used at both ends.
I assume you are sending note on/off, etc. information and not Sysex which MAY NOT be compatible between these units.
Jan 10, 2010 | Yamaha Music
Music Logo
120 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
