Question about Winchester Optics
I shoot Winchester super x 7mm rem mag 175 power point and I am looking for MOA ballistics for my vortex tactical scope can u send me a site where I can find this thanks
Savage 110 7mm serial num f255638 what year was it made
Try the resources mentioned in these forums. Savage used to have them on their site, but appear to have suspended the service.
Savage model 110 date of manufacture? ' The Firearms Forum
www.thefirearmsforum.com > ... > Technical Questions & Information Jun 21, 2010 - I have a Savage Model 110, 7mm Rem Mag with the serial number. ... I'm trying to get all my guns info on record and was wondering if anyone could tell me the year of manufacture for this rifle? ... but absolutly cannot find the exact year of manufacture?
What Year And Month Is A Savage Rifle Model 110(7mm ...
www.gunvaluesboard.com/what-year-and-month-is-a-savage-rifle-model... What year and month is a Savage rifle model 110(7mm) Serial#. ... what is the value of savage mod.110 7mm mag with simmons 3x9x32 synthetic s.
Savage 110 Date of Manufacture - Savage Shooters
www.savageshooters.com > ... > 110-Series Bolt-Action Rifles Jan 15, 2013 - 15 posts - ‎5 authors The model number is 110L-H in 7MM REM MAG and the serial number ... the bolt and barrel is 131057 any ideals when this Savage was born. Savage 110 5 digit serial number 6 posts 13 Dec 2014 Thread: LH model 110 EL series K 7mm Rem Mag 4 posts 20 Mar 2013 More results from www.savageshooters.com
Jan 25, 2016 | Optics
Ballistics for 22 mag
The ballistic performance of the .22 WMR based off 30, 40, 50 grain is 2,200 ft/s (30 gr), 1,910 ft/s (40 gr), 1,650 ft/s (50 gr). - See more at: http://gundata.org/cartridge/173/.22-winchester-magnum-rimfire-%28wmr%29/#sthash.qVd5FziR.dpuf 22 Winchester Magnum Rimfire WMR Ballistics GunData org
Feb 18, 2015 | Henry Repeating Arms Henry Frontier Lever...
Remington ballistics chart/ 7mm-08 R7M082
Your best bet is to call remington and ask about the bullet BC and speed. With this information you can use any of the free ballistics programs (online and for installation on your PC) to develop a ballistics chart.
Apr 24, 2014 | Optics
Can you explain to me about moas? i got this new p4 and im trying to learn how to use it can you tell me? and do i have to site it in at 100 yards first?
If you are going to attempt to sight in your rifle scope for hunting or just shooting, you will need a basic understanding of what a Minute of Angle is.
Think of a circle as it is divided into 360 degrees.
Each degree is divided into 60 minutes.
Each minute is divided into 60 seconds, but we don't use that for ballistics, seconds of angle are just used in machine shops and in rocket science.
Minute of Angle
1 MOA = 1/60th of a degree
1 MOA = 1.047 inches at 100 yards
Most accurate long range scopes are set in quarter clicks (4 clicks = 1 MOA) or eighth clicks (8 clicks = 1 MOA) but less accurate short range scopes are sometimes set in half MOA clicks (2 clicks = 1 MOA)? which to me is the opposite as it should be.
For a .308 the difference between shooting at 100 yards and at 500 yards is about 11 MOA. That adjustment with a scope using eighth clicks is 88 clicks.
Most accuracy testing is done at 100 yards, because it makes the math easier, and it is close enough to see the bullet holes through a spotting scope.
Folks usually say that 1 MOA is equal to 1 inch at 100 yards, which is almost exactly correct, as 1 MOA is only slightly more than 1 inch at 100 yards. But for what we are doing it is close enough. Now think it on out to 300 yards, 1 MOA is then equal to 3 inches. So if your shots are 1 inch off to the left at 100 yards; out at 300 yards, you will be off to the left 4 inches. Clear as mud? Hope this helps.
Jan 04, 2011 | NcStar 3-12x50e Rifle Scope Illuminated...
Scope wont track tried to shoot a square test and shot atrapazoid wouldnt track correctly at all shooting on a ruger 7mm rem mag
some scope wont do a square shot test,,but dont worry to much about this,, just clamp the rifle down and zero your scope ,,you get it dead on the rifle needs to be clamped down and not hand held
Nov 19, 2010 | Nikon Buckmaster 3-9x50 Matte Nikoplex...
Lost manual for trophy scope 3-9x40 rifle
There is no manual for elevation and windage adjustments. (at least not one that comes with your scope; all your scopes manual will say is whether its FFP or SFP (First Focal Plane or Second Focal Plane, the scale used on your scope for mil dots)(you can get this info by finding a store that sells this scope and asking a sales rep)
To adjust for elevation and windage you have to take into account the daily factors (unless your shooting in the same indoor environmental controlled shooting range each day you SNOB! jk
The formula takes alot of variables into account and is known as Exterior Ballistics
!) Environmental Factors - First thing you account for.
A) Elevation from sea level plays a large part into your environmental adjustments. Your elevation from sea level determines largely the Barometirc Pressure but it also varies slightly with Temp and Humidity (Major Factor)
B) Temperature - The temperature can affect the density of the air. The hotter it is the thinner it is and therefore less resistance and a higher bullet trajectory (Minor Factor)
C) Humidity - This again will affect the densify of the air infront of your bullet (Minor Factor)
D) Barometric Pressure - The other large factor in air density this is the base stat that the others modify
These all combined create a ratio that you apply to standard MOA (windage and elevation adjustments) to obtain the shooting information for that particular environment)
2) Bullet Factors (Listed on the Box you buy) - There are a few bullet factors to take into account.
A) Speed - the bullets feet per second can vary as much or more than 500 feet per second with the
same caliber ammunition.
B) Grain - The Grain of an ammunition is a measure fo its "Sectional Density" or weight to volume
ratio
C) Ballistic Co Efficient - This number is the measure of the bullets ability to maintain its speed
during flight. This also varies from Grain to Grain
These factors are complex and a pain for the best of shooters to determine. adding to that confusion. there are many ways to determine a bullets ballistics coefficient and each one gets a different number. In this case bullet data is best retieved from the manufactuerers box and take their word for it.
3) Lastly you account for shot factors.
A) Range - by referencing your standard elevation MOA adjustments and mutliplying by the ratio for environment the Elevation MOA is achieved.
B) Windage - Windage is done in inches per mile per hour then is multiplied by the Mph of the wind.
In order to be precise the windage is done in inches instead of MOA. it needs to be converted heres and example.
You Ballistics Cheat Sheet for the day says the windage at 900 yards is 5.2 Inches per mph of wind.
you apply the ratio for your environment .90 (all example numbers. this number would represent a shooting environment with an air density lower than standard/ the cheat sheet's known MOA adjustments). the 5.2 inches is multiplied by .9to acheive 4.68?? idk the point is you mulitply that by the wind of 10 mph to achieve a total of 46.8" of wind drift to the target.
now for the conversion to MOA. 1 MOA is eqaul to 1.047" per 100 yards. meaning for every 1 moa you adjust the bullet will move 1.047" per 100 yards (our target is 900 yards; meaning that each MOA for this target is 9*1.047" = 9.423" per MOA adjustment. so take that number and divide our total wind drift by it. ie 46.8 / 9.423 = MOA Windage Change of 4.9665... now you need to know whethere your scope is 1/4 minute clicks or 1/8 minutes (how many spaces between large numbers?) you would adjust to 5 MOA for a 1/4 minutes scope equaling 20 clicks on an 1/8th minute scope it would be 40 clicks.
This is the math of shooting. to learn how go to
WWW.shooterready.com they are an excellent sight to get the math down WITHOUT wasting ammo. Once you have the math you an transfer it to your gun. waste a few rounds checking it out and youll be hitting targets @ 1800 yards in no time
I like to take the simple way after i learned how to do the hard way
There is software tha will do the exterior calcualtions for you.
if your interested i use Sierra Infinity V6 Ballistics Software
GL
Dec 08, 2008 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Sighting in, clicks don't move where they're supposed to.
Ja, it's 1/4 M.O.A, so at 25 yards/meter it'll be ca 3 inches. You may have gone in the wrong direction. That is, if it was 3' high, and you went another 3 higher then you'd be at the top of the paper. Probably you've got it figured out by now.
The easiest, fastest, cheapest way to zero is with a rifle rest you can clamp your scope into, or alternatively somehow immobilize your rifle some other way. You take a shot, at 25 yards or so. It makes a hole. You now immobilize the rifle, via your rest or heavy sandbags, with the scope pointing exactly where you aimed before. You now, carefully and without moving the rifle/scope off of the point of aim, dial your reticle to point at the actual bullet hole. Your next shot will be at your point of aim now. So you just put it at the right height above your point of aim at 100 yards now.
Nov 02, 2008 | Bushnell ® Elite® 3200 3 - 9x40 mm...
Optics Logo
122 people viewed this question
Top Winchester Optics Experts
james laughton
james laughton
Colin Stickland
Colin Stickland
Fahr Quad
Are you a Winchester Optic Expert? Answer questions, earn points and help others
