Sorry but no. The good news is that you can add extra sound to make up for it with a surround sound system- a basic/inexpensive system is all you need- u get $100 all day every day!
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Do you have the original remote or a universal remote? On the original remote, the Eject button is also the Favorites (FAV) button. It's just below the Volume - section of the Volume toggle on the left side of the remote. The button has an upwards arrow above a line on it. You probably need to set the source to DVD for the Eject button to work properly. (If the source is TV, the button will add or delete the current channel to the Favorites list.) You can cycle through the input source options by pressing the Source button on the TV or the remote. On the TV, the Source button is between the Power and Menu buttons. On the remote, the Source button is on the right hand side above the Up arrow key.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If you wish to know its programming procedure, check the sites linked here. it is difficult to type all all here by this wondow. http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
0029,0022. Try these codes. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ http://electro-medical.blogspot.com/
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
