Computers & Internet Logo
Thomas Toon Posted on Sep 20, 2018
I have a lg bp630 3D dvd player that's new, only theres a problem, when i try find my wireless network to connect it wont find it, infact it does not find anything.. Cant try connecting via Ethernet cable as i haven't got one long enough.. Is there any solution?
rdarell
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Sep 30, 2018
rdarell
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
3638
Points
47
Use a wireless extender. Then from the back of the extender use Ethernet to plug to your player. Better still, plug it into a switch and then you can use the switch to connect multiple devices using Ethernet which is much faster than the built in wifi.
5 Related Answers
Jiri Sluka
  • 20 Answers
  • Posted on Dec 20, 2008
SOURCE: Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
ecmorgan69
Edward Morgan
  • 280 Answers
  • Posted on Dec 29, 2008
SOURCE: Wireless Connection failed
Did you make any hardware or software changes? You don't say.
Try seeing if your wireless radio is turned on. Most laptops have some kind of switch or Fn key combination that will turn off the wireless networking radio to save power. You might have inadvertently shut it off.
On the other hand, if it's a software thing and it only happened today, try using System Restore in Accessories --> System Tools and go back a day or two. If it's a software issue, that may resolve it.
Post back with any problems.
Anonymous
  • Posted on May 01, 2009
SOURCE: Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
Anonymous
  • Posted on Jun 09, 2009
SOURCE: Cant connect to computer via USB connection. Software wont open or reads no phone connected.
You probably have the USB selection set incorrectly on the phone. Go to Menu, then Connectivity, then USB, then select "Data Service". The should fix it.
Anonymous
  • Posted on Mar 09, 2010
SOURCE: Epson printer sx600fw, can't connect to wireless network.
How do I put my printer on my wireless connection
BD-J Error Code: 0108 has come up on my player how do I up grade? I have tried dowoading from a disc and memory stick but the blu ray player won't allow any what can I do?
If your blue ray player has Wi-Fi built-in and you have a wireless (Wi-Fi) home network, the way to do the upgrade is via the Internet by connecting the player to your Wi-Fi home network.
I have a lg tv and lg blue ray player if i get a rotor wireless one will it let me have the net on the blue ray player
Not sure what a rotor wireless one is. If you meant to say another wireless one meaning an LG or other brand blueray player with wireless capabilities then probably yes. Some players don't have an actual brower ability but alot if not most of them do. I am pretty sure the LG models do. The LG player you have now probably does unless it is really old but it may only have a network port on the back to hardwire to your network.
Hope this helps.
Lg blu-ray bp200 wont connect to wireless network for netflix
Change your network modem/router to WPA-AES only (remove the AES+TKIP setting).
New hp envy 15 My hp envy 15 is less then 12 hrs old, i am having a problem with the wireless connection. When i use my laptop in my living room where the modem is the wireless network works totally fine...
You may need a repeater /extender to amplify signal.
There are many variables that may cause network to drop. You might want to test another laptop before making any purchases.
Good Luck.
I have LG BD370, purchased a Netgear Wireless WNR2000 N-router, As recommended in the manual, I purchased a (Linksys Cisco Powerline AV Network kit model PLK300. That was connected w/ Cat 6 cables. Have...
Get a Wireless Access Point ($30-$50 average). A wire from WAP to the Blu-Ray player should work like a charm. The WAP pretty much takes your wireless connection and transforms it back to a wired Ethernet connection for devices like this. You can have your Wireless Router on one side of your house and the WAP on the other, right next to your blu-ray player with a short Ethernet connection between the two. The player will just see it as a standard Ethernet connection.
I just put the new Avatar Blu-ray DVD in my LG blu ray player, and an error message comes up saying i need to go to blu-ray.com/forbest results to get an update, but that website does not exist. How do I...
I have an LG BD390.
You probably don't have to update, despite that nag screen. My player is up to date and I see it, too.
If you want to update you'll need an internet connection. Assuming your player is connected with an ethernet cable or through wireless, go to the Home screen (that's what it's called on mine).
You should have a Settings icon or something to that effect. Your menu may be different but you should have options that are nearly identical. I can only write down what I see on my model:
Settings-->Network-->Update
From there you can check for updates and download them if you wish. On mine you cannot check for updates if there is a disk in the player.
Hope this helps.
1helpful
2answers
I have a new samsung BD-C6500 and can't get it connected to my wireless network. The closet I can get is this error message that says ''Physical connection established but cannot connect to external...
I had the same problem. You are right, Samsung tech support is awful. When I pulled the system out of my cabinet I was able to connect wirelessly. But in the cabinet it wouldn't work. I think my cabinet was blocking the wireless signal. Fortunately, I have a wireless ethernet bridge with a gigabit switch on my cabinet that hooks up my Panasonic plasma. I ran an ethernet cable to the BD-C6500 and the problem was resolved. If there is any way, try running an ethernet cable to your player. I know this defeats the purpose of wireless, but it worked for me.
1helpful
I am trying to set up the router for my LG bd 370 so I can stream netflix. My network is wireless so I do not remember how to integrate or install! I have a netgear RP114 that I am trying to use.
I have the same BD player. I have a linksys WRT610N router and i use a D-Link DAP 1522 wireless bridge to connect the LG player on my N network. The Bridge works great. If you want to stream in HD you most definitely want to have an N network to handle the needed bandwidth. also YouTube streams wonderfully also.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
