SOURCE: spin cycle won,t spin. starts then stops
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
SOURCE: GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
