Also, a wet-or-dry vacuum will help if there is still any water at all, and if you have only your house/apt. flooded, everywhere else outside is dry, some fire departments could be asked to help.
Fire departments have big, high volume fans for taking smoke out of buildings, they might help you .
God bless your efforts.
SOURCE: my basement flooded and now my gas water heater
Was the gas valve under water? If so it must be replaced. If not, and you're sure you are holding in the button for at least 30 seconds after the pilot is lit, the pilot will need to be removed disassembled and cleaned. Also, the thermocouple may or may not be bad, replace it anyway (for the cost @ Lowes etc just not worth it).
Testimonial: "I will try what you suggested."
SOURCE: speed will not adjust. will only run at high
if the board got wet most likely its shot its like dropping your cell phone in water it is not going to work rite or not at all
