Computers & Internet Logo
Jan Mortlock Jan Posted on Sep 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2005 Ford Fiesta 1400. The back window on the bottom right hand corner seems to have come loose and clatters when going over a bump. How can I fix it?
Jan
David Ellis Rhea
Level 3:
  • The Master 3,462 Answers
  • Posted on Sep 20, 2018
David Ellis Rhea
The Master
Level 3:
Answers
3462
Questions
Helped
784870
Points
10903
You will be needing to take that door panel off, and get a strong flashlight, and see if you can find the problem with the car sitting still.
If not, get someone to help look inside the door whilst you are driving down the road.
God bless your efforts.
5 Related Answers
A
Anonymous
  • Posted on Oct 15, 2007
SOURCE: Hand shaped icon in bottom right corner of Canon powershot S5 SI digital camera
It sounds like the image stabilization "on" indicator.
Anonymous
  • 17 Answers
  • Posted on Mar 21, 2008
SOURCE: Thinkpad T61 Display Problem
LCDs are not repairable, it is something you need to replace when defective. They also happen to be very very expensive to replace.
Is the screen cracked at all? cause sometimes when laptops get bumped, it is actually just the lcd cable inside the laptop that came a little loose and isn't making a full connection. If the screen isn't cracked or anything I would at least look into a possible loose cable first If you are not comfortable taking the laptop apart, I would bring it to a computer shop and have them take a look at it as some laptops can be complicated to open up. They shouldn't charge you more than about $40 to take a look at the lcd cable, they are normally pretty quick to get at. It is worth a shot as lcds typically range from $400 - $1000 and to have someone install it would be probably another $50-$100
hope this helps a little
Coss
  • 1056 Answers
  • Posted on Aug 01, 2008
SOURCE: Screen image is upsidedown
Hold down the CTRL+ALT keys, and hit the Up arrow on the keyboard.
Anonymous
  • Posted on May 07, 2009
SOURCE: one red light bottom right hand corner
Anonymous
  • 2761 Answers
  • Posted on Dec 14, 2009
SOURCE: My camera will cut on,
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Removing wing mirror electric on ford fiesta 2003 1400 zetec right hand side
Ooh..! It was a great idea. Its an innovating idea. you just careful while doing this or I recommend a mechanic to do this
Ford Fiesta 2005 Radio Code
Take to Ford dealer with proof of ownership and they will look up the code for you
2answers
Ford fiesta radio code m166781
NASTIF licensed keyshop (smith)
or your dealer. (oper. guide tell all this)
2answers
Rattle going over bumps seems to be coming from a
Check your back shocks the may be worn out.
Driving over bumps and rough roads I hear and feel of loose clattering or cliking sounds,as something is loose
most likely your problem is the exhaust system bumping. If it sounds like it is coming from front of vehicle, it may be struts clunking. Rear shocks can also do this if they are worn.
Top The Computers & Internet Experts
Alexander
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
