If the menu button on your Zoom H4n recorder is not selecting or responding when pressed, it could be due to a few different reasons:
- The button is physically damaged or stuck: Check the button to make sure it is not stuck or physically damaged. Sometimes dirt or debris can accumulate around the button and prevent it from working properly.
- The firmware needs to be updated: If the Zoom H4n recorder has not been updated recently, it's possible that the firmware needs to be updated. This can be done by connecting the recorder to a computer and downloading the latest firmware from the Zoom website.
- The recorder needs to be reset: If the menu button is still not responding, you can try resetting the recorder to its factory settings. This can be done by holding down the "Menu" button and the "Track" button at the same time until the message "Init All" appears on the screen. Then, press the "Record" button to confirm the reset.
If none of these solutions work, it's possible that there is a hardware issue with the recorder and it may need to be repaired or replaced.
