Question about Whirlpool Washing Machines
Trying to fix Whirlpool Cabrio Washer WTW555OXWO, what next?
Whirlpool Cabrio Washer WTW555OXWO, codes, F1E2 & F5E2 Motor Control Fault & Lid Switch Fault. Started investigations of the Control Board when husband mindlessly put a circuit checker on something, while the washer was plugged in, and made a huge spark/smoke. Saw that a capacitor was blown, changed that, didn't work, saw that the micro control chip was also blown. Ordered a used/but working control panel. Had a broken plastic pressure sensor piece, I exchanged those out. Control Panel did not work in washer, green LED light on though, used multimeter to check Power Supply, checked User Interface, put a different one in and the power button will not work but the knob will turn it on but it does not match up with the lights and the lid lock light flashes and the washer will not work or turn off with the power button.
    Sergeant:
  • Whirlpool Expert
  • 227 Answers
You got a lot problem be hard to tell you without be there to check your washer out you be better off call a techiacan to help you out ok.
Posted on Oct 22, 2018
2 Suggested Answers
6ya staff
SOURCE:
dyronwebb
Dyron Webb
  • 220 Answers
SOURCE: Whirlpool cabrio washer doesn't start, Can I fix this by myself?
If you replaced the lid lock then you know how to get the top of the cabinet up lift the top up there should be a technical sheet in a plastic packet on the front panel it will tell you how to run a diagnostic if not there turn machine off press and hold any button except power/cancel for 3 seconds release 3 seconds repeat until 88 appears after that any fault codes should appear I have only had to replace a control twice on these units I am curious to see if you get an F50 or F51 code this is the most common when this machine first starts the lid should lock a short rotation of the basket lid unlocks then locks a short fill then rotation of the basket let me know what you find could be the control but I would like to eliminate the rotor and RPS sensor
Posted on Jan 18, 2015
I have a whirlpool cabrio and the lid will not lock the light keeps flashing and it keeps making the lock clicking sound
BEFORE ASSUMING THE LID SWITCH NEEDS REPLACEMENT TEST WITH A METER, BUT FIRST TRY TO RESET CONTROL BOARD EVEN RUNNING A DIAGNOSTIC TEST WILL REVEAL THE SOURCE OF THE ERROR.. 1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). 2. Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: a. Press/hold 3 seconds. b. Release for 3 seconds. c. Press/hold 3 seconds. d. Release for 3 seconds. e. Press/hold 3 seconds. ? If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. ? If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause. If still unsuccessful, see Diagnostic: Unsuccessful Entry, at right. 3. The test sequence continues by checking for saved fault codes: ? If there are saved fault codes, see Diagnostic: Saved Fault Codes, page 2. ? If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
http://www.applianceaid.com/pdf/Whirlpool-Cabrio-Waher-WTW6600SB3-Tech-Sheet-W10026634.pdf
TEST #8 Lid Lock Perform the following checks if washer fails to lock (or unlock). 1. Perform Manual: Lid Switch and Manual: Lid Lock tests on page 2. 2. Remove the console to access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, at right. 3. Visually check that the P12 connector is inserted all the way into the machine/motor control. ? If visual check passes, go to step 4. ? If visual check fails, reconnect P4 and repeat step 1. 4. Check the lid lock motor winding and switches by removing P12 from the machine/motor control and checking the resistance values shown in the following Lid Lock Resistance table:
TO RESET TURN KNOB 1 FULL TURN COUNTERCLOCKWISE, THEN 3 TURNS OR CLICKS CLOCKWISE, 1 TURN COUNTER CLOCKWISE, 1 MORE TURN CLOCKWISE, THEN HIT START , ALL THE INDICATOR LIGHTS SHOULD THEN LIGHT UP, THEN UNPLUG FROM THE WALL FOR 5 MINUTES THEN PLUG BACK IN , IT SHOULD BE RESET AFTER PLUGGING BACK IN
Feb 11, 2017 | Whirlpool Washing Machines
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
    adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
    if machine is over 8 months old id suspect rust in lock arm as cause
    Jul 22, 2015 | Whirlpool Washing Machines
    What is the LF Code my washer puts out
    Hi Sherry,
    The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
    a. The fill hose may have a pinch or fold between the connections on the pressure in .
    b. Are the hose screens plugged at the connections.
    c. Is the water siphoning out of the drain hose ?
    d. Is the water pressure at peak, check valve, filters before washer.
    Now if your savvy hungry. Here is a learning curve link
    Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
    Okay. The next link is for the manual for your favorite machine. Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
    I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
    I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
    Jun 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
    My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
    Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
    check these one by one.
    Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
    Having trouble with my whirlpool cabrio . . . showing "DU" . . .
    The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
    Door Unlock Error
    A Door Unlock Error occurs if the door cannot be unlocked.
    It will try to unlock the door 6 times before displaying the error.
    Door Lock Mechanism broken.
    Check Door Lock/Switch Assembly for foreign objects
    Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
    Door Lock/Switch Assembly Failure
    If it is a cabrio:
    dU flashes if the following conditions occur:
    Excessive force on door lid is preventing lock bolt from retracting.
    Wash media buildup is preventing lock bolt from retracting.
    Machine/motor control cannot determine if door lid is in an unlocked state.
    TEST #8 Door Lid Lock
    1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
    2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
    3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
    4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
    resistance values....
    Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
    Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
    Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
    Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
    Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
    If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
    exists in the door lid lock. Replace the door lid lock.
    5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
    Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
    Thanks for using FixYa!
    Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Lid will not lock and just click click click (trying to lock but can't)..then "lid" is displayed and then f1.. sometimes I can (after trying different things finally get it to lock) Something like this...
    Hi
    Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Fault code F1 is flashing on my cabrio washer
    I have just gotten off the phone with Whirlpool for an F1 error on my cabrio washer. They are arranging for someone to come and fix my machine at their cost. It appears to be a common problem. Call Whirlpool and set it up. Good Luck.
    Jan 11, 2010 | Whirlpool WTW6400SW Cabrio Washer
    DU is flashing and when I press the Pause/Cancel button this does not clear the problem
    The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
    Door Unlock Error
    If it is a cabrio:
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washing Machines Logo
    188 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
