I have a Sony DSC-W110 and have set the date and time on the clock setting, however i cannot get the date and time to appear on the photo? What am idoing wrong?
Hello there.
You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen.
2 Touch [Clock Settings].
3 Touch the desired date display format, then touch [t].
The clock settings screen appears.
4 Touch each item, then set its numeric value by touching v/V.
5 Touch [OK].
To cancel the clock setting
Touch [Cancel] or [BACK] in step 5.
Sincerely,
Steve TM
Beacause the time is added to the display of the camera like other texts or symbols - it is not "written" into the picture. You can see it if you show EXIF data of the picture.
setting date and time on sony p32:
1)set the mode selector to photo mode 2)press power button to turn on the camera 3)select the desired date format and press ok/set button.
if date and time is set in camera correct the info is attached to each photo-even though you don't see it if you right click properties of photo it is there-some models don't offer date and time stamp because if you tell the printer to do it it should add it on print
Check the options carefully, and read the manual.If you don't have a manual, they are free for the download at Sony. Look for you camera under support/downloads. Some cameras only allow date and time stamp to be in certain resolution settings. It will not show up in other photo size settings.
