Maybe when the ignition coil heats up it will not produce any spark to the spark plug. Run the engine until it stalls and remove the spark plug and put the plug wire back on and ground the plug to the engine. See if you get spark at the electrode of the spark plug when you have some one pull the starter rope with the switch on the run position.
If there is a spark at the plugs ignition is fine, spraying starter in the intake should allow it to at least fire?? even if you had a carb / fuel issue. I would recommend a compression test and better still a leakdown test to determine if you have weak compression
If it has been sitting for a while the electrical field may need to be flashed. Check falshing a generator and follow the directions. This should excite the generator and start generating again.
Although this costs a little money, it covers most home gas/electric and industrial portable kerosine/diesel fired hot water pressure washers. Worth sharing...
