sbg6580 or what? you failed to use real model.
first off wired Ethernet is always faster.WAN (and the web actual)
say wifi not wireless there are many wireless and wifi is but 1.
there are 2 speeds, raw and real (throughput) latter is real.
and is bits per second not BYTES.
The
802.11a and
802.11g networks usually run no faster than 20 Mbps..
the answer is simple
one or both wifi devices is slow
either or both.
the speed will based on the slowest one, called band width bottle-necking.. just like driving a car really , traffic and narrow roads are slower. or are gravel roads, see?
so buy new wifi upgrades wifi 5 or 6, , 802.11AC or AX
yours is old and slow
and more money always buys faster cars or better roads or wifi.
speed costs and is not free.
read here first
but gee upgrades are the answer. but no hardware told yet
now just the modem/router your SB
Wi-Fi N300 2.4Ghz + N300 5GHz Dual Band Router.
The IEEE 802.11 Standard on Wireless LANs (Revision B, Revision G, and Revision N
so if he PC is not N or is not dual bad it can not do N speeds
or is B or G speed now)
100 Mbps is max speed on "N" 11N
and must be close to the router and both bands enabled on both ends and no huge traffic on those bands in your home or IOT there or in the hood (crowded apartments omg bad)
your router is not junk, but most old PCs are unless upgraded.
and lots of IOT things are 1 band and slow.
no brink or concrete walls from PC to router.
wifi is radio and does not link dense obstruction LINE OF SIGHT.
Ways to Improve the Speed of Your Current Router.
1. Automate a Reboot Schedule
2. Get a Better Antenna
3. Disable Older Wireless Protocols
4. Change the Channel Width
5. Keep Your Router Updated
6. Change the Channel
7. Switch to a Different Band
8. Install New Firmware
If you want to know more then it will better to contacthttp://wanos.co/wan-optimization/, which is one of the best networking service provider agency.
