If your Telefunken TV model TLEDD-48FHDA is producing sound but no picture, there could be a few potential causes. Here are a few things to check:
Input: Make sure that the TV is set to the correct input or source. If the TV is set to the wrong input, it will not display a picture.
Cable or HDMI connections: Make sure that all cable or HDMI connections are secure and properly connected. If the connections are loose or not properly connected, the TV will not display a picture.
Video settings: Check the video settings on the TV to make sure that the correct resolution and aspect ratio are selected.
Backlight or Inverter: It's possible that the backlight or inverter of the TV is not functioning properly. This could prevent the picture from appearing on the screen.
T-con board: T-con board is a circuit board that controls the transfer of data from the main board to the display panel. If the T-con board is faulty, the TV will not display a picture.
Main board: The main board controls the overall function of the TV, if it is faulty, the TV will not display a picture.
It's likely that one of the above causes is the problem. It's recommended to check the connections and settings first, if that doesn't solve the problem, it's best to contact a professional technician or Telefunken customer service to diagnose and fix the problem.
They were nice sets in their day. My dad had one in the 1960s. You will need a vintage radio repair engineer as the fault could be anywhere. They do still exist and Telefunken has a link to them.
See the bottom of this page for Photofact service manuals with schematics for additional Telefunken models imported to the U.S. manufactured after 1945.
Rating: 3.5 - 758 votes - Free
Control your Telefunken SmartTV over your mobile devices. ... Rod Doesn't recognisemy TV, keeps prompting to make sure it is connected to same wifi LAN, which it is. Adonis Kusema .... Pre-ordered. IR Universal Remote™ - IR 2.0.
May 21, 2011 - Av 10 Universal Remote Control Manual. (1 rating) ..... codes are ineffective or your TV srI brand is Dot oillbe code ..... TV2 0075 Telefunken TV
telefunken tv remote control DVD & Blu-Ray Players ... - Fixya
Does the TV and system have either a coaxil or optical sockets? If it does then I would connect them by one of these. That should trigger the sound. However it might work via the HDMI if you have selected the system to pass digital signals via that connection.
0386,0388,0380,0381. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier. http://electrohelponline.blogspot.com/
Hi, Sounds like the screen could have gone or the motherboard has something to do with it, try opening it up but be careful just to make sure everything is intact
As far as I know the only way to set lock mode on/off is using the remote. The only thing I can think of is unplugging power cord for five minutes to check if this reset settings.
