Plug in the eithernet cable while you try to connect the wifi and after it's working remove cable and try the wifi, I have a printer where the cable needs to be connected while installing the wifi and after working remove cable and works fine..
Had to factory reset TV
SOURCE: is there other way to recover my old password
You dont have to reconfigure if all you did was change to dsl.
Unplug dsl modem. Unplug router. Turn off computer.
Wait at least 30 seconds, plug in dsl modem.
Wait at least 2 minutes, plug in router.
Reboot computer. All should be OK. If not, reply back, and I'll helo you further.
SOURCE: cant get wifi on my ds even with WEP key
The DS doesn't have the best WiFi signal.
Make sure you are close to your router for one.
Also check the WEP key as it may say the AP (access point) isn't there if the WEP is wrong.
Also some routers won't connect properly to the DS unless the IP,Gateway, and DNS are set manually.
If you choose to set the AP info manualy then you need to find the you AP's IP address.
Commonly this would be 192.168.1.1 however it varies from one brand to another or may be changed manualy.
Try these settins with the corrected IP adress number as the gateway.
IP Adress 192.168.1.152 (this is you'r DS IP adress. The 3rd digit should be the same as you gatway's 3rd digit. The fourth digit can be any number that isn't used on your network.
Subnet mask 255.255.255.0
Gateway 192.168.1.1
DNS Pri 192.168.1.1
DNS Sec 192.168.1.0
(Usually I set the Gateway and DNS numbers the same and it usually works. The Gateway is the IP address of your wifi router.)
If this fails and all numbers are correct, then it may be that the WiFi router will not work with the DS as some brands simply refuse to work with it for unkown reasons.
Anohter solution is to get a WiFi USB dongle and connect to that.
SOURCE: Intel ProSet Wifi software can't connect to network
You need to manually add the network using your intel pro set utility. Or just switch to wzc.(wireless zero configuration). How to do it? just click start - go to run - type in services.msc - then look for wireless zero configuration on the list - right click on it then click start.
Then look for the wireless network connection icon on the system tray (that's in the bottom right hand corner of your screen). right click on it then select view available wireless network.
note: if you'll be getting the message "windows could not configure..." click change the order of preferred networks(that's in the same window where you're getting that message) then check the box that says "use windows to configure my wireless network settings" then click ok. after that go back to view available wireless networks then you should see your network now.
note: if you're using a corporate laptop where you don't have admin rights on it you need to use the intel pro
SOURCE: my PSP internet connection not supported to my access point.
The SSID is the NAME of your Routers connection. So you need to know your WiFi connections Name, That's the "Access point" Security, Is IF you assigned a WEP/WAP KEY, when the router was first setup. If NO Key is set, that is what it means "Unsecured",
You need to get a Netgear router manual, for your exact model, it shows all in pictures how to do it.
Hi karen cutchins, No TV model told????
answers come hard lacking that and or generic.
HOME TV?
do all thing in home wifi work and setup by you>??????? PC's or other TV or more? toys. wifi?
The router in the home has this.(setups)
it is called wifi credentials
SSID (wap1/2) and pass phrase
lost for forgot your credentials?
TV too far from router, over 25ft, or worse through dense or concrete/brick walls?
if your ISP owns your router, call them.
