It will depend on where exactly it has 'come loose' from. Considering the cost involved is it worth repairing?
If it is just the glass sheet and none of the working / moving parts, it is held in place with a strong adhesive/glue. It should re-stick with Careful use of a good quality contact adhesive or superglue.
If some of the mechanism has come loose it would be easier to simply replace the entire set of scales.
SOURCE: My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
