Check the water pump. If the pump shaft seals have worn out, it will leak water. I recently replaced a pump for a client with a similar problem but it wasn't shutting down from a short circuit caused by water. The pumps for Simpson machines are still in production and are quite easy to replace (find an appliance reconditioning shop and get a good used unit - it will save you some money). Also check the pump hoses for splits/leaks. Second place to look is the main agitator shaft seals for the wash bowl. This is a more involved repair and will require disassembly of the wash bowl/agitator to access it. There will also be a bearing on the shaft that should be replaced at the same time (washing powder is alkaline and will attack metal - once the seals protecting the bearings have failed, the bearing will rust out) Unfortunately the Simpson is a tough beast and isn't easy to tilt over to see where the water is coming from. You shouldn't need to turn the power on to find the leak. Just prop up one side of the machine with 2 blocks of wood etc and dump a few buckets of water into it and observe the underside with a torch (if it has been leaking substantially there should be tell-tale water stains in the vicinity of the leak)
SOURCE: washing machine fills continuously
I had the same problem as above. I cleaned the chamber attached to the bottom part of the bucket and used a syringe to push hot water down the this plastic hose that runs to that unit. I also made sure that the clip holding the plastic hose at both ends are fited properly. (similar to what mike has in solution 4). All sorted.
SOURCE: simpson enduro washing machine 701
HI thanks for the question. I would replace the water valve . this is a sign of a faulty valve. thanks . rate my answer please
SOURCE: machine will not stop filling with water
Does machine stop filling if you discnnect from power? If it does, the problem lies with timer/control unit, or fault in pressure switch/ tube. Check pressure tube (thin rubber pipe that goes from water level selctor switch to side of outer bowl) for holes- replace if faulty. You can test pressure switch by remove pressure tube from outer bowl and blowing thru tube- you should hear the water level switch click when you blow, and then click again when you release pressure. If it keeps filling even with power off, you have a faulty inlet valve. If you remove top panel (3 screws along top rear-power off first!!), you will see the inlet valves- one for hot, one for cold. The valve is the thing the inlet hoses screw onto. New valves availble from any good spare parts supplier, relatively inexpensive part. Good luck!!
Testimonial: "Exactly pipointed the problem which is now fixed Thank you"
