Toshiba 32A33 32" TV Logo
Mahmoud AbdRabo Posted on Sep 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need software for toshiba 32PB10E - Toshiba 32A33 32" TV
goneforever.
Level 3:
Top Expert:
  • Toshiba Master 14,531 Answers
  • Posted on Sep 30, 2018
goneforever.
Toshiba Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263482
Points
66315
It is a TV, is it too hard to say TV and post to TVs and not computers.
toshiba 32PB10E no not software, it is firmware, you TV has no HDD.
my wild guess is you want new APPS "smart apps"
if yes tell what app you want
better ask Toshiba that, only they can upgrade TV's
all you can do got to settings and click upgrade my firmware
if you told us and APP that fails. only Toshiba can fix that.
only them .
its not a computer, its a TV with fixed APPS.
If you said my old Toshiba, netfix app is dead (as they all are)
then we have 1 fix only.
Old TVs smart have old APPS, that are not dead, obsolete or random failing or acting half deed.
all mine do, even on 2 new (panasonic/sony blu-ray)
and my LG TV
all 3 makers flat refused to upgrade my netfix and hulu apps
and that is forever issue, dead forever.
the cure is ROKU 3 and ROKE ultar 4k
ROKU ugrades when the sourced (say neflix) tells them to.
The apps had a major change 5 months ago, at 3 of my streaming sources rendering all 4 smart appliances here dead.
ROKU saved the day. (im older than dirt and this is not spam)
moving to TV where you belong now.
paul wilson
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 52 Answers
 paul wilson
Expert
Level 2:
New Friend:
Night Owl:
Answers
52
Questions
0
Helped
18274
Points
103
Google toshiba homepage with make, model and serial. If it is in stock they will sell you a new set for around $50 , tell them what o/s you are runniing
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
TV Channels are not stabling.
The main system control memory IC fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
I have Toshiba Regza 32pb10e LCD TV & I have no color blue in my picture
If you have reset and t to factory default and this problem still persist you will need the services of an electronics technician. It is possible that the motherboard has developed a component fault
3answers
How i download toshiba e studio 166 software
Software & driver can be download via business.toshiba.com
1helpful
Update firmware lcd tv toshiba 32pb10e
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
Picture ovelap toshiba 32pb10e
Sounds like T'Con fault. Contact any service technician to confirm. Gopakumar Gopalan Google
2helpful
Toshiba REGZA LCD 32PB10E why when I play video in the flasdisk, the color is just black and white .... please help me ...???
Sounds like your connected component video. Try connencting with the yellow white and red cables. Also the unit might be set to progressive scan. Try dropping resolution within the player. Hope this helps.
How to download the webcamera driver or software and wi-fi
For drivers and software of your Toshiba computer, you can visit, www.toshiba.com and you can download the drivers and software you'll be needing for your web camera and wi-fi.
For further assistance, please provide us more information about your Toshiba computer.
Thank you,
Jack
Wireless Network Driver
Dezzie.
This software will work with your Toshiba Laptop. This software was created by Toshiba. You need to install the Network Adapter. So go to Toshiba's website and update your network adapter drivers for win XP SP2.
Please let me know how this works.
Thank you
Cabletech
Need old drivers and software for Toshiba Pdr-2 digital camera..
Hello , I am in need of software for my toshiba digital camera PDR 3330. I need to instal the pictures to my pc. can't find any software , please help......... where can I get
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
