SOURCE: Elna 2002 Sewing Machine
Can't get a manual for you but here's how to wind a bobbin.
Guide your thread from the spool holder to the bobbin thread tension device on the top left side of the machine.(That's the round assembly that is about 1/2 inch in diameter with a screw in the center of it.) Pull the thread in the front and wrap it to the back and continue towards the bobbin winder on the right side top. Wrap thread around the bobbin, place the bobbin on the spindle sticking up. Release the handwheel(either by pulling out on the center of the wheel or twisting on the center of the wheel). Press on the foot control. It should stop winding when it is full.
To thread the machine
all machines thread the same. TTN tension, take up,
needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way. Flat side to the back and it threads front to back
Sewman7
SOURCE: Manual to Elna Lock Pro5dc computer sewing machine
i hope this link will be useful for u to download the manual
but u need to select the model no
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ELNA
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
SOURCE: Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Hi Helen Bermingham, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I searched and could not locate a free manual or a paid manual for Elna 501.
I saw an Elna 500 manual for sale, if you are interested.
https://www.sewingpartsonline.com/instru...
Thanks Terry, but I’ve checked them out also, no good. Many thanks for your help
Thanks Andrew, my machine is definitely an Elna 510. I brought it from Spotlight in Western Australia in 2016
