Service number 0467965189 Sim Serial No 882837271 IMEI: 356163044564454
Contact Telstra for assistance.
https://www.telstra.com.au/account-services
https://www.telstra.com.au/account-servi...
Unsure if this is the Telstra service contact for you or not.
SOURCE: Telstra prepaid mobile unlock
hello there....well its quite simple...to unlock the phone to any network you need to call the customer care of your original network provider( Telstra) ....just keep the model number of your phone number handy (you will find that on the box in which you got the phone)...or the IMEI number (15 digits mostly) by dialing *#06# on your phone or beneath the battery or on the box near bar code....this is a paid service and charges differ from network to network
that should solve the problem.....you will be able to use any sim in your phone of any service around the world
hope this help
SOURCE: Need a puk code
Pin codes and PUK codes are meant to protect the sims.
If you wrongly put PIN Codes a number of times, to really protect your sim it will ask you a puck code. (Please note every sim has its unique PUCK Code.)
Pincode/Puck codes for any sim are provided by the service provider. (In your case, Telstra an Australian SP).
You may require to contact your Service Provider Network and speak to Customer Service Representative for getting this information (PUK code).
Kindly dont apply any more codes any further or otherwise the sim may get permanently blocked and you may have to replace it.
Please rate this support if you find it useful.
Regards,
Techno-Geek.
SOURCE: i want to unlock my telstra t6 so i can use other
go to www.howardforums.com all the info you need on unlocking cell phones will be there. good luck..
Unlocking helps to remove the network lock..So that you can use with other GSM Network sim card in it.IMEI Number is Unique for every mobile..IMEI means International Mobile Equipment identity.Using the IMEI you can identify the mobile phone model...It's unique for every phone.It will not same...While Unlocking you need to specify the brand ,model ,network,country it's locked now ,IMEI number
S/N is RF1C57WBP7B
is serial number..
You can get the Unlock code for SAMSUNG E1190 model Phone at
Classicunlocking.com/samsung-e1190/rs17wp9/ and Unlock it from Vodafone network lock..Then use with Telstra Australia or any gsm network from any Countries.
