My washing machine washes the clothes, spin and then stop and the "pre- wash" and "time save" lights start to flicker. The only way to let it work again is to switch it off and start the whole program from the beginning. Most of the time I have to do that several times. When I spin it then it does not spin like it used to and sometimes it start flickering lights
1) Hold in the Pre-wash & soaking buttons TOGETHER; 2) At the same time, turn the knob clockwise from the OFF position, to "Short Spin". All the LEDS light up. 3) turn the knob anti-clockwise to "energy saving" 4) Machine is reset and the door release clicks.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Erratic behaviour in wash programmes can often be due to clogging of the path between the tub and the pressure sensor which senses the water level in the tub. Clogging can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme.
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
