Good morning I'm trying to download my fotos from my S3 to my pc but it wont open my fotos. says cant access fotos
There are several methods you can use.
1.The easiest way it to use Samsung Backup,which can connect your Samsung S3 to computer via WiFi and enables you to move photos from device to PC directly.
2.USB cable, every modern PC has USB port that you can use.And this is the most usual method.
3. Install Google Drive app on your Samsung and PC,and then sync the photos via Google account.
I transfer photos from my phone to my PC using AirMore. It's free app to transfer files between mobile phones and computers. May it can help you. https://airmore.com/
You can download shareit for your PC and transfer files from your mobile to PC via WiFi.
Shareit file for PC https://en.softonic.com/download/shareit/android
SOURCE: LG Prada Phone and how to download mp3 onto it
my phone does not recognise the external memeory card how do i install that
SOURCE: i cant down load videos onto my pc..
xfer the videos to the memory card and connect the phone as mass storage and manually xfer the videos from one folder to another. Your phone will appear as Fat4 drive.
SOURCE: my sigmatel s3 cant connect to my pc or any other pc
the best solution for you is to use a bluetooth usb adapter (if your pc doesnt have one) to transfer files. The advantages are much more with this connection than over the cable... the cost is minimal (in greece its about 12 euros) it will solve your problem and the most important thing is that bluetooth is compatible with all the mobiles so you will not need to install different softwares for different mobiles (which may mess up your xp) and use different cables. if for example your next mobile would be a samsung and your brother has a nokia and your father has Sony ericson what would you do ? install 3-4 diffrent softwares and connect / disconnect cables ??? no... - get a bluetooth...
SOURCE: donwload of the fotos
1. Insert the Motorola Phone Software CD in the CD Drive.
2. The setup will launch automatically.
3. Select the appropriate software (PC Suite / Phone Software) to install.
4. Folow the instructions that appear and complete the installation.
5. Restart the system.
6. Start the PC Suite / Motorola Phone Solution software.
7. Click on 'Connect to phone', and follow the instructions.
8. Connect the cable between the phone and PC when asked.
9. The PC will detect the phone automatically.
10. Now, you can download the pictures from phone to PC easily by selecting the appropriate option!
please rate this advice if it hepls...tc! :)
connect data cable with your pc and select media transfer option and then copy in yoyr pc or sync your photos with google photos and login with google account in your pc and download from google photos
