Televison & Video Logo
Xolile Dazela Posted on Sep 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My TV is Sinotec LED 43 inch HS-2110H-00 - Televison & Video
  • 1 more comment
  • Paul Bade Sep 28, 2018
    Hi Xolile Dazela, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    I see from another post you made that you are apparently having a problem with the backlight on your TV.
  • Xolile Dazela
    Xolile Dazela Sep 30, 2018
    Thanks a lot Paul for your answer. I'm scared to try and fix it because my TV still has warranty
  • Paul Bade Oct 01, 2018
    If it's still under warranty, by all means take it in and make a warranty claim.This is obviously a defect and should be covered. Do it as soon as possible.
Paul Bade
Level 3:
  • Master 1,818 Answers
  • Posted on Sep 28, 2018
Paul Bade
Master
Level 3:
Answers
1818
Questions
Helped
574867
Points
5816
The most common problem with backlights in an LED TV set is a failed LED. While these are supposed to last 30,000 - 50,000 hours, they are very sensitive to static electricity damage. This does not show up immediately, but after some time, the LED may flicker, then burn out, or burn out suddenly.
On many LED TV models, the backlight will come on, then turn off if one of the LED strips is bad. Test procedure: unplug the TV set, wait 10 seconds, then plug it back in (or turn off the power strip for 10 seconds if you have the TV plugged into a power strip). Darken the room, then turn on the TV while watching the screen carefully. If you see a horizontal section of the TV that is darker than the rest of the screen before the screen goes completely dark, that is where the bad LED strip is.
If none of the LEDs light up, even briefly, the problem may be a bad LED driver circuit. This is often part of the power supply board, but may be a separate board. The LED driver board is identifiable by being connected to a cable of three or more single wires (not twisted pairs or flat ribbon) going into the metal back pan of the TV, generally to the upper left side (viewed from the back). If the driver is separate from the power supply board, it will have another cable going to the power supply board..
Repairing a bad LED is labor-intensive.
1. Disconnect the TV from everything and remove the back cover. (at this point, you can plug in the set and repeat the LED test, and watch the various holes in the metal back pan to see if the LEDs flash when you turn on the set. Be very careful - there are exposed high voltage connections on the power supply board when the TV is plugged in, even if the set is off.
2. Make sure the TV is unplugged. Remove the shield from the T-Con board (at the top or bottom of the TV, centered horizontally).
3. Unlatch the flat cable connectors between the T-Con board and the edge of the LCD display.
4. Treat a section of clean carpet or large beach towel with anti-static spray, then lay it on a flat surface (make sure there are no foreign objects in this area; you don't want anything punching into the LCD). Lay the TV face down on this mat.
5. Remove the stand if it is still attached.
6. Remove all of the screws from the perimeter of the LCD. At this point, it is very desirable to have a helper. Lift the TV upright, holding it by both the front bezel and the metal back pan. Remove the front bezel (on most models it is held on by plastic tabs with hooks as well as some of the screws that were just removed).
7. Check for another set of screws that hold a rectangular steel frame or set of steel strips to the edge of the screen. Lay the TV flat again and remove these.
8. Very carefully unfold the connector strip(s) with the T-Con cables from the frame and lay them flat on the mat. Avoid any stress on the ribbons between the strips and LCD glass; if you tear or pull loose any of them, the display is ruined. Avoid touching any of the metal circuit tracing on the strips or the bare metal on the ends of the T-Con cables - static electricity discharge may damage the display.
9. Gently lift the back part of the TV (the metal pan with the circuit boards attached) off of the display. Two people are recommended for this task, especially for larger sets. On some models, it may be more workable to remove the LCD and diffuser sheets one part at a time while the TV is held upright. Make sure to keep all of the layers in the proper order, including front-side alignment, and put them on a clean lint-free surface.
10. There may be a white plastic reflector pan covering the LED strips in the back pan. The plastic is typically very thin and delicate. Carefully remove it.
11. Now you should have the LED strips exposed. At this point, you can plug in the TV and turn it on while watching the LED strips. (Caution: there are exposed high voltages on the back of the TV. Do not touch the power supply board while the TV is plugged in!) You will see the good LED strips flash while one or two strips remain dark. The bad LED is on one of the dark strips.
At this point, you have several options: 1. Replace the entire set of LED strips. If one LED has been abused (excess current or static electricity), chances are others in the set are also damaged. 2. Replace just the failed strip(s); 3. Identify and replace the bad LED; or. 4. Replace all of the LEDs in the bad strip(s). The strips are usually held in place by double-sided tape or a tacky adhesive. LED replacement requires tools for soldering surface-mount devices. If there is a circular piece of white plastic tape around the LED, carefully peel it off and save it, and likewise pull off the lens that is glued on over the LED before attempting to remove the LED.
White LEDs are blue LEDs with yellow phosphor painted on top. Blue LEDs are more vulnerable to static damage than other colors due to their strained-crystal construction. Consequently, parts with blue or white LEDs should not be handled unless electrostatic discharge safety measures are practiced.
3 Related Answers
Back2life Electronics
  • 933 Answers
  • Posted on Oct 03, 2012
SOURCE: Sinotec LCD LED 42 TV does not switch on only have a red blinking light
The set has an internal fault and needs to be serviced
Testimonial: "Thanks, Am sending it back as it is only two weeks old"
gopakumarg43
  • 76851 Answers
  • Posted on Feb 21, 2016
SOURCE: Please email me tv manual of this tv sinotec smart tv 43 LED STL - 43E 390M full he 1080
Your email ID?
johnny rebel
  • 604 Answers
  • Posted on Apr 19, 2017
SOURCE: does the hitachi 43 inch freeview play smart LED tv have a headphones socket, and if so, where is it situated?
yes,it is on the back,it is a black hole
Sinotec stl 43-e black screen when insert hdmi cable there is sound but no picture
If you are getting sound from your Sinotec STL 43-E TV but no picture when you connect an HDMI cable, it's possible that the issue may be with the HDMI port itself or the cable being used. Here are a few things you can try:
1. Check the HDMI cable - Try using a different HDMI cable to connect your devices. It's possible that the cable you are using is faulty or damaged.
2. Test the HDMI port - Connect a different device, such as a DVD player or game console, to the HDMI port on your TV. If there is still no picture, the HDMI port may be damaged and may require service or repair.
3. Reboot the TV and devices - Turn off the TV and the device you are trying to connect, unplug them from the wall, wait for a few seconds, and then plug them back in and restart them.
4. Update firmware - Check whether there is a firmware update available for your TV and update it to the latest version available.
If none of these steps solve the problem, it may be necessary to take your Sinotec STL 43-E TV to a licensed technician for further inspection and repair.
2answers
58 inch SINOTEC UHD NETFLIX LED TV NO PICTURE BUT HAS SOUND
The backlight led is burnt out, time to replace with new one. Most of the time it’s only 1-2 led are burnt. You need an electronic technician though. I may guide you if you want further assistance.
2answers
Manual for sinotec STL-50E6000m where to get on internet?
hi a few months ago half of my picture just went slightly darker than the top half. this morning. the whole picture went dark but sound still there nd a very faint pic almost black tho. what could be the problem with my 43 inch model stl-43e 3000g nd were in Cape town SA can i buy the parrs i need to fix it. seems like the power board could be faulty
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
