Televison & Video Logo
R
Ruth Perkins Posted on Sep 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound goes out during programs on our Westinghouse t.v then comes back on at random
While watching a program, the sound suddenly stops. If I turn the t.v and t.v dish box back on and off, sometimes that works, sometimes not. Sometimes it comes back on by itself. It's all random. Not tech savvy so have checked for loose connections, done resets, etc. but don't have any other ideas
Kenneth Walker
Level 2:
Sergeant:
  • Expert 293 Answers
  • Posted on Sep 29, 2018
Kenneth Walker
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
93342
Points
736
Ln audio Settings, make sure Main Audio is selected and SAP is turned off.
5 Related Answers
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on May 28, 2008
SOURCE: Turns off by itself!!!
The flyback transformer are damaged .
Anonymous
  • Posted on Jul 31, 2008
SOURCE: screen goes black but still have sound
MINE TOO AND SANYO TOOK THIS TV OFF ITS SUPPORT WE SHOULD ALL SUE THIS COMPANY [email protected]
Jannarama
Jann Schott
  • 14 Answers
  • Posted on Mar 19, 2009
SOURCE: Problem with sound and picture
If you have Cox Cable, and are using a Scientific Atlanta box, AND have "On Demand", and the volume suddenly goes out, turn your cable to the "on demand" channel (in Phoenix, AZ it's channel 1) and that usually restores the sound.
It's a known issue, and so far this is about the only solution that works quickly.
Anonymous
  • 1779 Answers
  • Posted on Jul 15, 2009
SOURCE: 40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Anonymous
  • 4 Answers
  • Posted on Sep 19, 2009
SOURCE: Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Machine comes on at random times, which it is not set to do
Sounds like leaving the carafe empty has caused over heating damage, this in turn probably generated a random fault on the program.Programable micro chips have a default reset pin, a safety factor when built in to machine circuits. The chip now appears to have 'cooked off' causing failure to operate according to the program. Any temperature over 55 degrees C does this to any non-NATO standard chip.
2helpful
Westinghouse lt609s Washing machine has stopped and will not progress HC error
Possible fault in the main program controller unit. It is important to test the sequence and output of the program , the voltages to the motor during the wash cycle drive motor, the input valve and output valve voltages at the point of cycle to confirm the program controller.
TV goes blank - no sound or picture
Sounds like a bad capacitor or two in the power section. Do you hear a hissing sound also?
2answers
sond slike bad tv almost is your power strip grounded well bets one is monster clean power clean up older homes power so dirty in usa cuses flat screens to die out elery if u have up down voltage in house also cheak hd antenna whos your cable from charter or dish
1helpful
2answers
Sound Starts on Then Goes Off Randomly
I actually fixed the problem. It was a driver issue. Try this with your sound card program. I opened up the program in charge for sound. In my case it was soundmax. And pressed the load defaults button and clicked apply and everything started working again. The same thing happened again after a while so I pressed defaults again and it worked. But It happened again so I uninstalled the drivers and updated them. Everything was fine after that. Now I have a problem with my registry.lol
Hope it helps.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
