Control wires damaged, replaced and blower keeps running after temp is reached, any ideas
SOURCE: carrier model 58sxa080-gg series 100
the flame detector rod is dirty? try cleaning with sand paper and scraping also. there should be a small amp. reading threw wire coming from flame detector rod. in milli amp range. increases when running. some times i use a jumper to hold gas valve on once started to allow time to test amps.
SOURCE: Coleman Evcon furnace, blower runs
make sure the thermostat is in the auto mode if so it is more than likely the fan relay control some are built on the board some can be replaced separately
SOURCE: Replacing Blower Motor Resistor
SOURCE: blower fan keeps running even aafter the engine is shut off
3 Inspect Thermostat Faulty Thermostat. 4 Inspect Antifreeze Needed Coolant Level Low.
