It worked for 5 minutes after taking it off the charger and then just died. I have cleaned the battery terminals, tried everything I can think of. Is there hope?
SOURCE: Razr v3 dead battery
you have a dead battery, this happens often. all you can do is just buy one, ebay
SOURCE: Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
SOURCE: Nokia N73 Music Edition Charges Forever
try factory reset ...... if that does not work get it checked with the nokia service center
SOURCE: I can't find where the fuse box for the radio for corolla 2006
Pg. 250 of your 2006 Owner's Manual shows the location of the Fuse Boxes. There is one under your hood on the driver's side and the other is under the dash just to the left of steering wheel. Pg 272, will show you how to replace the fuses. Pg. 286-287 gives a diagram and description of each fuse and what part of the electrical system it enables.
I blew a fuse while using my Cigarette lighter/power outlet to inflate my tires. It took out the power to the car stereo, the clock below it, and the two Cigarette lighter/power outlets.
This portion of the electrical system correspondeds to the fuse in position 32 on pg. 287 of the manual.
Your going to have to get on your back with a flashlight and open up the fuse box under the dash by the steering wheel. The lid of the fuse box shows the positions of the fuse and their amperage rating. Like I said, replace the fuse in postion 32 (15 Amp). There is a spare 15 Amp fuse in the fuse box under the hood (easy to get to, see the diagrams in the owner's manual). There is also a fuse puller tool next to the spare fuses.
I hope you would be able to find the radio Fuse.
Any further questions regarding replacement, feel free to contact me.
Thanks for using Fixya.
I tried the soft reset when it wasn’t plugged in and when it was. It didn’t do anything at all. Any other ideas? Would a bad battery keep it from powering on even when plugged in? Thank you so much for the help.
It would be odd for a battery to catastrophically fail from one minute to the next, but having said that Lithium Ion batteries are highly volatile. My advice is to take it to a mall phone repair shop. They can open it up and test the battery. It may also be a faulty on-off switch. Depending on make and model, spares are available, and batteries definitely are.
