Try restoring it to factory settings. I found these instructions and hopefully they'll help you to disable the channel lock problem you have -
How to Find the Reset Button on an Akai TV Techwalla com
SOURCE: Television "locked"
Yes only the original remote will unlock it. 10 out of 10. I have unlock it also with Ellis universal but buttons is not the same.
SOURCE: sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to [email protected]
SOURCE: AKAI TV UNLOCK
hold the lock key in the remote for few seconds . you ll get the lock tool bar . yo can unlock it there. it worked for my akai 14 inch tv.
Turn
on the TV and grab the remote. In most cases, you will need the original remote
to unlock the TV if you aren't sure of the unlock code. If you don't have the
original remote, you will need to purchase one.
Look
at the screen. If you see a blank screen with a red key on the bottom of the
screen, press 'Function' and 'Mute' at the same time. This should unlock the
channel. This is an option for people who want the TV to stay locked but, want
to be able to bypass the lock to watch a certain show or channel. All other
channels will remain locked and the TV will fully lock when it is turned off.
Unlock
all of the channels on the TV by entering the factory reset code. There are
three main reset codes that TV manufacturers set. These are 0711, 6688 and
3308. Try each one until you find the one that works. This will reset the TV to
original factory settings. When you do this, you will loose any information
that you have stored in the TV, such as favorite channels, automatic timers and
the clock. You will have to go through the full initial set up.
Call
the technical support service number in your owner's manual if none of those
codes work. A technician can help you troubleshoot the television because the
problem may not be the locking control. When you call, make sure that you have
the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted
trouble--if it gets accidentally turned on and you don't know the code,
you can find yourself unable to fully enjoy the full range of available
television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching
regular TV ....
