SOURCE: How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Appliance_Zone_Refrigerator_Install_A_Refrigerator_Door_Gasket.htm
This should help!
Brad
SOURCE: I need to change the door seal on a 1990 ge fridge
place new seal in warm water for 15 min. start at one corner, remove appr 4 srcews in each direction pull old gasket down. now start to install new. continue to remove old and install new. make sure to remove weight from door. after your done place a film of vasoline on mating surface.i sometimes will roll a small amount of paper towel to insert where gasket is not wanting to pull up . push door firmly shut for a few days.
SOURCE: new roads NSW north coast
Garmin updates new Maps annually, if new roads were built after the last update you would need to buy the new Map to get the roads...
SOURCE: Hi, we moved the sub woofer
Where was it sitting before it was moved? Did it have it have more ventilation and keep cooler? This sub has a powerful amplifier in it. If it got moved to an area that restricts air circulation around the sub more it is possibly overheating and causing fuses to blow. Put a fan on it and make sure it is on a hard surface or up off the carpet at least to keep the bottom side cool as well. Also when one moves a speaker it's often to put it into a more convenient area to be able to turn it up louder with less disturbance to others. This will draw more power and create more heat within the amplifier than it's previous location. If this is so keep it as cool as you can and turn it down every so often to give the amp a rest. The key here is to keep it cool as you can. One thing you never want to do is put a higher rated fuse in than the unit is rated for. Always use factory recommend fuse rating.
