Televison & Video Logo
S
STEPHEN WATKINS Posted on Oct 02, 2018
Factory reset for Marantz UD 5007
CANNOT PLAY BLUE RAY. NEED TO UPDATE. ALSO REMOTE DOES NOT RESPOND
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 29, 2008
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
Anonymous
  • Posted on Apr 13, 2009
SOURCE: Pioneer DBP-51FD Blu-Ray
I bought mine four days ago and it would not pay the new James Bond Blue-Ray. The screen said your player needs an update. I downloaded the firmware, and it still did not work. I took the disc down to Best Buy and it played fine on an identical DBP 51-FD. Their tech came out with a replacement player and it played fine. Now, however, it will not play the DVD Happily Ever After 2, eve after the firmware update. Strangely enough, the other player played that DVD fine.
In other words, take it back and get another one.
RixsFixes
Radio Code Pro
  • 2200 Answers
  • Posted on Sep 02, 2009
SOURCE: my ps3 doesn't play blue ray movies
This is a common problem on the PS3 unfortunately and is caused by a faulty blue-ray drive. Unit will have to go back to Sony for service.
You should try a DVD cleaning disk first to be sure that dirt on the laser lense is not causing the issue.
You can also open the case and clean the laser lense with a Q Tip and an alcohol cleaning solution.
If you plan on opening the case at any stage please ensure the unit is disconnected from its power supply.
If this fails and you are confident with electronics there are several videos on YouTube showing how to replace the drive if you choose to order it and do it yourself.
See an example below.
Hope this helps. Please remember to rate my answer. Many Thanks
Anonymous
  • 632 Answers
  • Posted on Oct 18, 2009
SOURCE: want to update my sharp blue ray disk player bd-hp21u
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Anonymous
  • 513 Answers
  • Posted on Apr 16, 2010
SOURCE: need the code for a sony dvd blue ray play to
Here is the link for the RC64 remote (You did not give a model number)
1helpful
ALBA tv/dvd combi LCD26ADVD only plays in black and white and does not respond to the remote anymore since my toddler got hold of the remote, please help
Remove batteries and disconnect power to reset. If that fails go to settings and restore factory defaults. Alba should have web site to help.
1helpful
The remote does not work
Hello my Marantz dv4100, didnt respond to my remotecontroll, Remote was working. remote from my philips dvd722 works fine with this Marantz-dvd too.
i found 2 solderings at the back of the front circuitboard in remotecontroll receiver optounit at the left side of dvd-display, pins 1 & 2 needed resoldering, had cracks in solderings. after that it was working fine again.
hope this helps u too.. good luck!
3answers
Won't play new blue ray disk
Will your machine play standard movie DVD discs? if it does then the laser pickup assembly is the problem. The blue ray discs require a higher precision tracking to offer better resolution.
For no reason I know of, my Marantz SR8001 will not come on and the display will not light up. It will not respond to activation using the power button on the display panel, or the power activator on the...
blinking power lights are a factory setting to inform the customer there is an internal electronic fault. and the unit needs to be repaired by a service pro in 99% of cases the owner can do nothing to fix it.
send it in
best luck
2answers
My blue ray won't play blue ray disc's it's already played and it won't play new ones
You can try getting it professionally cleaned but it sounds like you need a mechanism unit and that exceeds the cost of a new bluray player substantially. Make sure you have gone into the menu and under software update there is system reset. Make sure you have completed that system reset and make sure you have the latest software update installed. Sometimes after playing a movie you have to complete that system reset in the menu and the reset whereby you hold down the power button ON THE UNIT ITSELF NOT ON THE REMOTE CONTROL until the unit says reset.
My lg superblue bh200 will not play the princess and the frog and toy story on blue ray but plays all of my other movies fine. All it does is ask for the language and then goes black.
Hi. I have Toy Story on the Lg bd 560 bluray and discovered the same thing. There are two ways that you can get it to play. Go to factory reset in the menu. This is called initialize software on my player. It should now play without any problems. The only trouble is that if you turn off your player and back on again, it will not work until you do another factory reset. The easiest way to solve the problem is to disconnect your internet connection[no more factory resets required]. For some reason this movie does not like the internet being connected on my bluray player. I have told LG Australa about the problem and they will probably fix it in another firmware update. All the best.
BD300 will not play a Blue Ray DVD. Do I have to
If it plays a normal DVD then the answer is maybe. If it played Blu ray before I would try cleaning the eye! If it never played Blu-ray then your unit is bad. Suggest sending it directly back to ther factory!
Rate this answer....
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
