Question about Refrigerators
106.56679500 ice dispenser, crusher is not working
The ice maker is working and the water dispenser is working
    Top Expert:
  • Refrigerators Master
  • 6,289 Answers
Are you getting cubes? There’s a solenoid that controls that. It switches it from cubes to crushed. If you’re getting neither, then the auger motor is probably bad
Posted on Oct 02, 2018
6ya staff
SOURCE:
Anonymous
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
duby1990
Justin Duby
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
Anonymous
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
Anonymous
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Posted on May 22, 2009
mreid542
mreid542
  • 166 Answers
SOURCE: ice crusher not working
Remove the ice tray and check to make sure that it is not froze up with with ice. the bottom of the tray has a rod attached to it that controls a flapper that opens and closes to allow the ice to pass thru without hitting the cutter or closes to hit crush blades. make sure this is not in a bind or froze up. this rod goes into a plastic housing at the back of the freezer that has a solenoid switch that activates it to open it up. check to make sure all of these items are free of ice and in their proper position and or not broken.
Posted on Jul 24, 2010
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Amana side by side ice maker tray is full and frozen but cubes aren't being ejected
Make sure the ice crusher/dispenser is working or gt a technician 2 look at it. Also ensure that u do not spil water when refiling the ice maker n do not go beyond the full markings 4 this may cause malfunctions when the water is frozen.
May 05, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Siemens Refrigerator model KA58NA70NE The ice maker section is not working. Please advice how to fix it.
I had the same problem and fixed it by changing freezer fan found underneath the freezer inside body, just behind the ice delivery/crusher motor. You need to open all the inside upper components like ice dispenser, ice maker, ice crusher motor, lamps assembly and finally the rear upper inside body cover. First, check whether or not the fan has strong air ventilation before trying to change the ice maker fan motor.
Feb 04, 2011 | Siemens KA62DV50GB Side by Side...
The ice dispenser and water dispenser on the door will not work
"Prepare for the worst" This is a problem i'm currently dealing with at the moment, ice maker thaw'd and refroze the ice as a block, binding the crusher turbine till it quit working. then water dispenser started spitting till it quit working, but anyway i disconnected the ice maker and water dispenser power hookup, because when i tried to use it it was drawing off the power of the fridge. now i'm to the point where fridge clicks like the relay is going out. in the back of the freezer below the ice maker tray i removed the clip or screw to where when it clicks i can hand spin the cooling fan on the click, and fridge starts up and runs, but don't remove this panel because having it on helps the air push into fridge compartment and keeps cooling elements from turning to a block of ice, " so long story short " its either your cooling fan or relay on chip board that starts cooling fan, i'm no expert but this is where i'm at hope it helps.
Jan 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water and ice maker not working line frozen everything frozen even when you turn it down is it the termostat or what
It sounds like your ICE Dispenser door is stuck partway open. Defrost the access door, ice bucket and crusher then check the Ice Dispenser door to be sure it fully closes, otherwise cold air will constantly drift out and freeze the whole mechanism.
Mar 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a kenmore elite model number 795. my ice dispencer only gives crushed ice even though its set to cube
1st i would remove all ice out of bin, clean outBIN with warm water under sink. put ice back in do not throw away for testing purposes. if worked then a cube may have been caught in bucket chopper improperly . if didnt change anything could be a bad crusher solenoid. in home service could run you 90-145 dollars depending where you live. if you do it yourself crusher dispenser solenoid will run about 30-50 DOLLARS. hope this helps
Sep 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
NO ICE AND IS MAKING FUNNY NOISE
I also have the same model as you. My problem with the ice maker has been build-up of ice under the cube pan which holds the crusher and cubes. ( I pulled the pan out and cleaned up the ice, pushed and re-seated the pan against the back of the freezer where it connects into the crusher motor). In a day or 2 it was working fine again. I got this problem because my son was pullying the pan out and emptying all the ice-cubes into his cooler for his bottles of water and soda., He was not pushing the pan back far enough to seat into the motor of the crusher and this left room for the ice to accumulate under the pan and pushing it forward away from the crusher motor which makes a loud noise when the pan is not seated correctly. There is another problem I had because the freezer was opened to often. The door dispenser became warm and the crushed ice accumulated in the dispenser and froze there, so if I opened the door, ice-cubes would fall out of the pan all over the floor. Also check the back of the pan where the crusher connects to the motor, mine was full of frozen moisture turned to ice which kept the crusher from seating properly. If this is not your problem then I would call a repairman as doing it yourself can be expensive because you may buy a part and then find out the old one was ok and it still doesn't work. Ice maker parts are very expensive .If you are positive that you know what is wrong then by all means fix-it. Also check your frozen food if it is frozen solid or soft, you may have a completely different problem than the ice-maker. Hope I helped some.
                                                     Jerry
Sep 06, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
