SOURCE: Frigidaire Front Load Dryer
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
SOURCE: Washing machine won't do final spin.
Remove the front lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out, refit carefully and give the washer another try. The companies dont tell you how to do it, for their techs then won't make any money. A tech to clean your filter!!!?? $$$
You're free to rate me............not that i get anything. Happy laundry!!
SOURCE: Drum came loose on Fridgedaire front loader on final spin cycle.
What was the point of posting this on the site?
The drum has broken loose from the support plate at the rear
You need a new drum and a support plate plus probably an outer shell.
A complaint to the manufacturer may get you a deal on a replacement
SOURCE: my GE model wcvh6800j1ms front
Front right would most likely be the discharge pump. Here's a diagram:
Sounds like you could have a pump problem or a loose hose. First, go ahead and clean the drain pump filter (as per instructions in the Use & Care Manual). Screw it back in tightly to see if that resolves the issue.
If not, check this posting for how to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you don't get any error codes and all tests run correctly, open the front access panel and see if you can figure out where the leak is originating from (To remove the panel: undo three screws and lift from the bottom).
Please post back once you either have codes or have located the leak source...then we can troubleshoot more.
