Toshiba AW-DC1300W start process intterupted by beeping error E64
Hi, my Toshiba AW-DC1300W top loader washing machine keeps cannot start washing process. When started, i hear whirling sound several times to finally interrupted and beeping into error E64. What can actually causes this problem? Thank you.
    Top Expert:
  • Washing Mach... Master
  • 6,289 Answers
Could be something hung up in drain pump
Posted on Oct 05, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: samsung sw51asp top loader washing machine
I had the same problem and from bit of research dE probably means door error. It turns out to be the reed (magnetic) switch was not functioning properly so wasn't closing the circuit when the door is closed.
DO NOT DO THIS UNLESS YOU HAVE BASIC UNDERSTAND OF ELECTRICITY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Of you may really harm yourself.
To test if your problem is the reed switch then 1. Turn AC power OFF, unplug from wall 2. HAVE YOU TURNED THE POWER OFF? 3. Unscrew two visible screws on the back of the machine near the top 4. Take back lid off by pull up which will expose all the wires at the back 5. Put your head in the drum and look to the right under the edge you will see two wires (may be blue) connecting to a small rectangular grey unit (reed sw) 6. Follow the wires back to the back where all the wires are you will find there is a clip joiner - unplug it. 7. Use a multimeter (if you have one other wise skip to step 8) put the probes across the wires coming from the reed switch and you should find the circuit opens and closes as the washing machine lid is opened and closed. If it does not then pretty sure the reed switch is not working then follow step 8 to short it and test. 8. Another method is just to short the wires by jamming a wire across the connector that goes to the machine and NOT the connector to the reed switch This will bypass the reed switch detection so will always be a closed circuit. But since it still has a lever door open detection system it doesn't really matter.
Try a washing cycle to see if it has fixed the problem.
If you have the means then replace the broken reed switch by buying another one from your local shop.
If your problem with the dE error is not with the reed switch then it may be with the lever system which I have no experience with.
Samsun SW51ASP top loader washing machine dE error
Posted on Oct 03, 2009
Anonymous
  • 81 Answers
SOURCE: Toshiba 62HM84 Starting Problem
you need a balist.
olso in the cust menu is a quick start mode . turn it off
Posted on Nov 18, 2009
Anonymous
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
syd_2811
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Posted on Aug 28, 2011
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Toshiba washing machine AW-A820MM cannot be Start and spinning. When turn on can hear sound "tark-tark".
i have the same problem here, i hate this machine. i suggest don't buy toshiba machines, its useless
Sep 23, 2016 | Washing Machines
Whirlpool Washer lsr5233a
Well sounds like a new timer is needed or timer motor - but these mechanical machines are difficult to diagnose as they dont give fault codes. The timer is a mechanical part and subject to wear and tear - cogs and motors wear out. Modern electronic machines don't have this problem, and timers are very expensive and difficult to fit for an amature. How long have you had the machine? I know top loaders last longer - but maybe time to upgrade to a new one
Jan 02, 2018 | Whirlpool Washing Machines
Samsung top load gets to final spin and bangs around like crazy, then it will stop, refill, drain, and start that process all over again. I've leveled it over and over, but that doesn't seem to help.
Washing machines have springs to keep the tub centered. If one or more of those springs has come off or has broken, you'd get exactly those symptoms.
Jun 08, 2015 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Nov 13, 2010 | Washing Machines
I have a nec nw-652 top loader when i start the machine the water fills the tub but at the same time i can hear small amount of water is going down the drain then stops. Once the water in machine is topped...
Hi just read your posting.Now can you please let me know where your drain hose is draining to,Is it into the laundry sink or some place else.Can you see the water coming out of the drain hose?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 18, 2010 | Washing Machines
My whirl pool washing machine no longer spins. I just stopped on day. I can hear the motor trying to turn the drum but it doesnt.
Hi. This is a possible broken belt. You will need to access the drive assembly to confirm. The symptoms you have posted will often lead to a separated belt.
NOTE(IF this is a top loader, and you are hearing noise during the spin attempt, this will lead to failed motor coupler. Please disregard this note if the unit is a front-loader)
Oct 08, 2009 | Whirlpool Washing Machines
Kenmore needs help getting the spin cycle started
clutch is worn - needs replacement.
Aug 08, 2009 | Kenmore Washing Machines
Washing Machines Logo
472 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
