I have an older DLP screenplay 4800 and I need to connect it to my new MacBook Pro, what cable would I need
As Verb75 says - you just need the right cable.
SOURCE: Cannot connect my new Apple MacBook Pro to mt DIR
No -there are no drivers to install. I would even suggest not to use any CD that came with the router (in your case the so-called "Quick Router Setup Wizard CD".
It is always better to configure the router by hand, otherwise you have to look forever if you have to troubleshoot.
If you connect your Mac to your DSL- or cable modem, can you access the internet?
If yes, then you have to configure your router. If not, then there is a problem with your internet connection in general and you have to contact your ISP.
Connect to your router (via cable) and check that the SSID is broadcasted and your wireless security is turned off, until you can connect wireless to your router. Look at the manual page 22 (if you don't have a manual, you can get it here.)
Then follow the Wireless Security Setup Wizard (ideally do it manually, but this works too). You find a description up from page 64 in your manual. For now, select no wireless security and complete the wizard. Don't forget to save your settings.
Now you should be able to connect to your routerwireless from your Mac.
After this is accomplished, go back to the wireless security setup and secure your network with WPA2 Authentication.
If you have any more questions or get stuck at one point, just come back here and leave a comment - I'm happy to help.
SOURCE: I'm trying to connect my macbook pro to a Benq DLP
You will just need one Serial connector from your Laptop which goes to Benq DLP projector and your Speaker cables if u have one..
SOURCE: panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
SOURCE: Iomega Screenplay Pro HD - No Menu
I had the same problem with the Screenplay Pro HD. My Iomega was working fine and one day after exchanging files with a friend I got the logo, then the loading message and then it went into a black screen while the blue light kept blinking.
Obviously the connection to the TV was fine because the logo appeared.
I solved the problem by downloading and reinstalling the firmware.
I downloaded the firmware from the iomega web site.
Notice that during the installation process you get the message that it will delete your data and then shortly after you have the option to delete or keep it. Hang in there. This part is a little nerv wrecking.
Hope this helps.
Rainer
