SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
SOURCE: Cyan, magenta and yellow not print after replace the new print head
I am going back to Epson
SOURCE: Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
SOURCE: printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
SOURCE: CLP300 Laser Black print is feint (pure black comes out 25% grey)
change the trasfer belt .
Testimonial: "Fast response - many thanks."
