2 times
reason:
1,check the cover of the lamp,
there is a siwtch under the cover of the lamp
make sure the switch is on the right place
2,air film,
there is a siwtch under the air film
I am an expert of repairing projectors for 19 years.
It is my pleasure to receive the message form you,
WhatsApp ID:+8613178867858
Skype:[email protected]
Wechat ID:+8613178867858
Email:[email protected]
Mobile:+86 13178867858
http://www.lampdeng.com
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Hi David
I think you should replace the lamp.
SOURCE: power up
Hi mick1907
Take out your lamp and check for any irregularity like marks or discolouration.
If there is no visible damage - put back the lamp and take of the top cover - start the Projector and check if all your fans are running - that is if the machine starts at all.
If the unit doesn't start up at all you will have to replace the Mainboard.
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
SOURCE: Red power light and buzzing sound with red lamp light.
If the lamp does not light at all, it is probably a bad lamp. The buzzing may be the ballast trying to start the lamp or a problem with the power supply. Check the lamp and see if the arc tube is broken. If its a new lamp, you should be under warranty. I have the manual if you want to go to me site at allprojectorlamps.com. Just send you email to me attention Bulb Guy
