SOURCE: Bernina Activa 130/131
Because you say all was working for a while before this latest event, it will be the supressor that has failed, they are generally in the foot control (some machines have them in the main body near the power inlet) and it needs to be removed, it only stops interference to Radio & TV and is not necessary for correct function...............your nose will tell you if it is in foot pedal or inside the machine..
Unplug from mains, undo cover/s and find the electronic looking item which is cracked, burnt & probably oozing brown goo and smelling like burned plastic only worse.... Simply remove this from the circuit, clean the region with some denatured spirit, methanol or similar, wait until completely dry and re-assemble....this should fix the problem of the machine "running on" by itself....as to whether you have done a good job of the initial electrical repair, only you will know that.
By the way, how's the dog ? Guess the machine was not plugged in at the time !!
SOURCE: Needle doesn't move the problem isn't the foot pedal
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
SOURCE: elna 7000 computerized sewing machine
just wonted to see how much these elna 7000 are running now i have one but i just wonted to see what its worth now
SOURCE: Bernina 900 ''Electronic Power'' foot control needs repair
You will need to go a bernina dealer to by those pins the part number is 325 355 031 and each pin cost around $4.00 each
