Question about Fisher and Paykel Washing Machines
Front loader fisher and Paykel won't drain and spin
    Top Expert:
  • Fisher and P... Master
  • 6,289 Answers
Check drain pump for operation or obstructions
Posted on Oct 08, 2018
Testimonial: "I followed your instructions and now I’m just putting my machine through a cycle so far so good, I’m from Australia ???? and our closest repair person is a couple of hours away, so as you can imagine he charges an arm and leg to look at it. And that’s before he even puts parts and more labor on to his bill. So you have saved me heaps thank you so much ??"
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
douglas smith
  • 1462 Answers
SOURCE: Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Posted on Nov 14, 2008
Anonymous
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: My Model GW712 won't spin or drain Top loader
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Posted on Nov 06, 2010
duke918
SOURCE: Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Posted on Dec 08, 2010
I have a fisher and paykel top loader 10 kg but not spinning and make that humming noise when it's on spin cycle, water drains slowly.....please help
sounds like theirs a large blockage in the drain pump housing, the drain pump is just twist locked onto the bottom so you just lift the little white lock clip then twist the pump and it will come off and you will be able to see inside the housing and clear the blockage
Jan 28, 2017 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine top loader doesnt spin dry the clothes well. There isnt any water in the machine after the spin cycle but the clothes are heavy wet. What's could cause this?
Machine not spinning. Have you stood next to machine and listened? When all water is drained out (watch the drain hose for water to stop) then you should hear the spin start and hear it building up speed. If it doesn't then you need to post back here with more detail on what you could hear or see happening. i.e. how long after water stopped draining did machine finish and switch off?
Nov 05, 2016 | Fisher and Paykel Washing Machines
Hi I have a fisher Paykel washer front loader wash smart, it has err 37 flashing and doesn't seem to spin or drain water
I no some of them have a filter at the front right down the bottom just about under it i no this can cause that problem
Aug 28, 2015 | Fisher Washing Machines
My Model GW712 won't spin or drain Top loader fisher & paykel
best of luck
Nov 06, 2010 | Fisher and Paykel Fisher & Paykel Washer
Ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
I have a problem with white depost on black clothig after final spin in my new eco top loader
it is either he detergent or limescale got to espares and but the lime scale and gunge remover
Jul 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
May 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
204 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
