where is the heater relay? I am a competent caravan engineer who is electrically savy but don't know anything about appliances. And what results should I be looking for from the relay and heater. The machine in running and heating but beeping e15.where is the heater relay? I am a competent caravan engineer who is electrically savy but don't know anything about appliances. And what results should I be looking for from the relay and heater. The machine in running and heating but beeping e15.
You can't post conmments that contain an email address.
E 15 is an error message. Turn the machine off from the socket. Unplug it. Change the cycle to a different start point. It may have a worn bearing because of overweight and resists the weighthe bearing because of damage. The weight is important to regular functions.
The control unit on the tumble dryer will vary among
different makes and models. The main purpose of the controls is to allow
the user to select the drying cycle. You can choose the time and
temperature setting on most units, while others allow custom settings
such as moisture sensors and end-of-cycle alert signals. The controls
may include a dial or a touch panel and LED screen display. Some tumble
dryers allow you to independently select the appropriate time for the
load you are drying and separate programs for temperature.
Motor
The motor inside the tumble dryer spins the basket to allow
the clothes to tumble while being dried. The tumbling action allows the
air to pass through the clothing to dry them faster. Heating laundry
that is stagnant will likely dry the clothing on the outside while
leaving damp clothing inside the pile. The constant motion, along with
the heat and steam created by heating the clothing, reduces wrinkles.
The motor also powers the fan that delivers the heated air to the basket
of laundry. The heater can be an electrical element or gas powered.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
