SOURCE: Need to know the watts on a Fridaire Air Conditioner 6000 btu
check your name plate voltage and current rating, multiply it and the result is the wattage of the unit.
SOURCE: Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
SOURCE: rv air conditioner leaking
I have the same problem....it is a negative pressure problem holding water inside the unit until it overflows the pan and runs into the duct system. why this occurs....I don't know....I cant find a problem with my air return, but as soon as you turn in off, the water comes gushing out the drains on the unit. I resolved this....temporarily....by twisting up a paper towel into a wick, and placing one end up into the drain tray, with the other end lying well out into the exterior case. This lets the water wick out and keeps the tray drained. I don't understand the problem and don't know what the permanent fix will be, except maybe cutting a hole and placing an intake vent directly below the unit.
SOURCE: Valsi Generator 7500W no output voltage
If its a Generac could be the voltage regulator or control board. If you want to go inside then disconnect the avr (voltage regulator) from the field and put 12 volts to the field slip rings with a car battery. Watch Polarity.... Yu should get about 60-80 volts out of the 115 receptacle. Plug in a light bulb and see if it lights. If it does then the field and stator are probably ok and you need to look elseware. Make sure breakers and connections are ok from the stator and receptacle.
