SOURCE: kitchen aid top loader washing machine does not spin
Peace Friend,
ngfam1 At your service!
Sounds like a belt problem!
Or the linkage connecting the transmission to the agitator.
Or the WORST THE TRANSMISSION IS GOING!
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
SOURCE: Goodman Model GMNT100-4 Auto Power Down and Up until Temp.
Keep in mind all furnaces and circuit boards are not the same. Look on the back of the door to the blower compartment. You should find the list of diagnostic codes. Look up four blinks it should narrow down the problem. Although from the discription you gave it sounds lie the high limit control. When a high limit appears to be acting up it DOES NOT mean that the high limit needs replaced. The high limit just may be doing its job. This means that the furnace is overheating. Check your filters. Are all of your registers open? Is your blower set on the right speed? Is your blower going bad? Is the blower motor capacitor bad? Is your evaporator coil restricted? Just changing a high limit switch does not always solve the original problem!
Good luck....
SOURCE: de error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
