SOURCE: Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
SOURCE: kodak esp 7 has a
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
SOURCE: i have Kodak esp 5 all in one- says I have paper
paper jam problem and it did not help try the procedure below. Works for esp 7.
backward.
SOURCE: got a paper jam how do I take off the back to fix
Log onto www.kodak.com/go/itg and follow the online steps to either resolve the issue or tell you to contact Kodak for replacement.
Testimonial: "Was helpfull"
