SOURCE: memorex dvd player pscan split screen
Memorex MVD2042 - The only switch on the back of the unit had gotten bumped when something fell behind the unit, thus causing the same issue mentioned here. Looking at the front of the unit, the switch is straight back from the disc tray on the left. (of course, if you're looking at the back, it's on the right side) This switch is for "Progressive Scan" either "on" or "off" Thanks, Wizard_Yo
SOURCE: Blank LCD screen
Thanks for that link, I will keep it handy! Be careful however, because the exact same symptom can be caused by a stuck shutter. To tell if it is a stuck shutter follow these steps: 1. Turn off the flash!! 2. Look down into the lens. 3. Take a picture. Did you see anything change? The opening at the center should be momentarily covered by a matte black shield. If you take a picture and see no change inside the lens then the shutter is stuck closed or open. If Canon finds your shutter to be stuck and not a CCD failure, the repair will not be free.. very not free. David Millier Advance Camera Repair
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
SOURCE: LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
SOURCE: I have 40? LCD Samsung flat screen TV model:
check power supply capacitors..i repair these every day and the power supply is prone to faulty capacitors..the capacitors should have flat tops and if they are bulging or leaking brown fluid, replace
