Question about Symbol Computers & Internet
SK-8165 top left above F keys has symbol for home, email etc last one is a lock which is usually lit green. When light goes out, I cannot type. What to do?
    Top Expert:
  • Symbol Master
  • 53,770 Answers
Press the scrlk button in the top line of f keys
Posted on Oct 12, 2018
Anonymous
SOURCE:
Anonymous
SOURCE: Classixx 6 1200 bosch washer...I've
You've put the child lock on! When powered key press the on/off button for 5 seconds. This will remove the key!
Instruction Manual can be found here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Dec 14, 2008
Anonymous
  • 4 Answers
SOURCE: Dell keyboard SK-8115
(That is the the Num Lock indicator, nothing to worry about.) If it is not working it is likely because USB keyboards can time some time to be recognized by windows, let the computer boot up with the keyboard connected and let sit for up to ten minutes.
Sometimes if other hardware is detected at the same time which requires drivers to be installed, windows will never proceed to installing your keyboard, however you cannot install the other drivers until you have a working keyboard. To solve this, you will need to use an older style PS/2 keyboard to get everything installed and working as they do not need to be detected.
Posted on Jan 08, 2009
Anonymous
  • 591 Answers
SOURCE: on boot up a lock symbol with a '9' is lit & nothing else happens
the "9" inside a lock means that your Num Lock button has been pressed. If all you see is the ">" then maybe you are looking at what's called a DOS prompt, and I have no idea why that would display. Try holding the Power Switch for 10 seconds and restart your computer. Hopefully things will be better, and you know where your Num Lock key is.
Posted on Oct 11, 2009
Anonymous
  • 41 Answers
SOURCE: The warning light above the airbag light on the dash. 2002 VW
Malfunction indicator light it is the symbol of your engine with a line of suffering and the word "CHECK" -- this could be something minor like needing a spark plug to be replaced (common problem) or to something more serious like engine electrical work needed. a flashing engine light is the more serious so you are not to worry.
keep this handy: http://www.newbeetle.org/forums/2-0-liter-gas/39141-where-can-i-find-warning-light-diagram.html
Posted on Nov 07, 2009
Anonymous
SOURCE: Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Posted on Dec 23, 2009
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
How do I cancel the control lock
It would help if you gave the brand and model number of your dishwasher, but the answer is basically the same. Look carefully at your dishwasher control panel. You probably have a little lock symbol that is lit up (or a light inside the symbol is lit). And usually this lock symbol is located near (usually above) a button that is usually used for another purpose. Most often this is the Heated-Dry key or button. Press and hold this key for 3 to 5 seconds until the lock symbol light goes out. And it's just that easy! But if you press the key, and nothing happens, then you may have a bad control console that will have to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 25, 2015 | Dishwashers
Kenmore ultra wash machine won't run even with indicator lights on. Symbol on machine says Lock on
You have the control-lock function turned on. There should be a key located near (above or below) the lighted lock symbol. Usually, it's the Heated Dry button. Whatever it is, press and hold that key for 5 seconds. That should unlock your dishwasher and you can now use it normally.
Jul 15, 2014 | Kenmore Dishwashers
Dell inspiron 1501 laptop keyboard is typing odd numbers and symbols instead of some of the lettters. Examples, the letter "l" comes out "3" . Other letters come out as a back slash, etc. A plug in USB...
Is the Num Lock light lit? This light is the one all the way to the left of several on the computer to the left of the power button (it looks like a padlock with a 9 in the center). The integrated number pad is probably active. Press to toggle this feature off. The Num Lk key is to the right of the various function keys but to the left of the keys labeled Insert and Delete.
I hope this helps.
Oct 16, 2010 | Dell 0Y3740 Keyboard
If i press function key then all the keys work good otherwise keys just type numbers.
You have the number lock in the ON position.
The function key is usually of a different color (usually blue or green) look for the key with has the words Num Lock of the same color as the function key usually its the same key as the ScrLK (scroll lock)key. While holding the function key press the number lock key then release all keys and try to type.
Most computers have a light that indicates when the number lock is on just like the Caps lock on a desktop its on the keyboard, on a laptop the lights are either above the keys or on the bottom of the screen, look at the lights and you should see a number 1. if its on then follow the steps above until it turns off.
Good luck
Oct 10, 2010 | Computers & Internet
Key board troobleshoot
Your NUM LOCK key is turned on. Look closely at the top row of keys, you should see one that has an icon of a number inside a padlock, or it might say NumLock, NumLk, etc. Press your function key, and while holding it down, press the numlock key as well. You want to press them both at the same time.
You should also see a light somewhere as well. Usually an icon of a number inside a padlock. When you turn Number Lock off, this light will go out.
Jun 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
Dell inspiron 2200 laptop - what are the 4 lights on top right of keyboard for? the first one is constantly blinking and the others are never lit up
Hi those are your keyboard and status lights
Looking at your laptop from the front the first light on your Right hand side is your scroll lock light and is only on when you press the scroll lock button (the symbol shows a lock with a little down arrow)
The light to the left hand side of that light is your caps lock light and again only turns on when you press the caps lock key (The symbol shows a lock with a A in it)
The light to the left hand side of that is your numeric keypad light (Symbol has a lock with a 9 in it), this comes on when you press the num lock key on your keybaord
Finally the last key is your hard drive light (like a cylinder), this will be flashing most of the time as you use your PC as it is constantly reading and writing data
Regards
Shauqat
Jun 10, 2010 | Dell Inspiron 2200 Notebook
How do I get a "CAPS LOCK" indicator or light to appear?
Most keyboards now a days usually tell you on screen whether or not the caps lock is on but its possiblbe that when you press the key yowards the left or right hand side a light goes on or possibly in the top center if this is not the case then you may have a faulty keyboard.
Nov 27, 2008 | Microsoft Wireless Laser Desktop 4000...
How to use calculator portion of DELL Keyboard
if you want to use the number pad, you have to make sure the the number light is lit, the number light is the lock symbol with 9 inside it. this symbol is found at the top portion of the keyboard. if its lit then you will be able to use the number pad.
Oct 07, 2008 | Dell 0Y3740 Keyboard
Computers & Internet Logo
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
