Question about Whirlpool Washing Machines
Hi there what does error code F 0d mean on a whirlpool 10kg 6 sense washing machine?
    Sergeant:
  • Whirlpool Expert
  • 227 Answers
F0d mean slow drain check your pump an drain hose for lint clog up
Posted on Oct 22, 2018
6ya staff
SOURCE:
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: fault code
I have look over the codes for your model and dont see an FH code if you post your email here i will send you the service manual
Posted on Jan 26, 2008
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: what does F7 mean on a whirlpool 6th sense washing
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
Posted on Jul 30, 2009
Anonymous
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
Anonymous
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
burgessmk6
SOURCE: bosch washing machine error code
what does F'18 means?
Posted on Mar 06, 2011
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
HI, WE'VE GOT A WHIRLPOOL 6TH SENSE WASHING
washers are very expensive to fix they cost more to fix then to buy
Aug 09, 2013 | Whirlpool Washing Machines
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a Whirlpool 10KG washer HDW1011W9. F 33 is flashing.Please can you help?
WHEN CONNECTING THE WATER HOSE DO YOU NEED TO PULL THE BUNG OUT FROM THE BACK OF THE MACHINE
Mar 27, 2011 | Whirlpool GHW9400 Front Load Washer
Water not coming inside the washing machine
Water not coming inside solutions:
1. Make sure the inlet has water or the faucet going into the washing machine inlet has free flowing water.
2. Did you turn on the machine on?. This is required specially for heavy duty 10kg Whirlpool industrial grade washing machines..
3. If the two above didnt work. Try rotating the knob to NORMAL and pull it.
4. Contact the nearest Whirlpool service center for repair if problem persists.
Hope this helps
levibit
Dec 13, 2010 | Whirlpool Washing Machines
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Hi There
  • Check the MCU
Dec 11, 2009 | Whirlpool Washing Machines
Washing Machines Logo
144 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
